Hey guys just seeing who left in Melbounre has ceffys!! A few mates I knew that had em either sold up or moved interstate- I wouldnt mind another meet up but seriously I know only 1 person with a Registered ceffy at the moment!! Ive owned my Ceff for 18 months and they just keep getting rarer and rarer!
Just wanted to see if any newer ppl on here had accquired any!
https://www.sau.com.au/forums/topic/204004-melbourne-ceffys/
Yeah im in the sth east.
Theres a couple around here as well, i dont know who they are though.
Some asian chick in a white one with 3 spoke advans i think
And i saw another white one that i gave the thumbs up a few times in my ceffy on blackburn road
And i dont know if its still his but i used to see ontryl every day on the way to work
Yeah if people get a few ceffys together im keen to organise a meet up.
Ive met ONTRYL ages ago, dont know who it is.
anticeptik are u the ceffy that came to the hills run in pakenham a few weeks back?
  • 3 weeks later...
I seen that Gold Auto Indulgence ceffy at the RE customs dyno day but no owner.
Who is that and wats the story with that car?
That was my old car. Glad the new owner is looking after it. Its exactly how I sold it.
What story you after about it?
I've still got mine...white autech kitted, that may of been me you saw anticeptik, as i used to drive on blackburn road quite a bit untill recently, now I only drive my car occationly on weekend.
Starionturbo from memory I think our 2 ceffy's are the only ones on carsales in VIC also.....
  • 2 years later...
Spotted an exact replica of my ceffy in Dan_J's driveway.
lol did a double take and almost crashed into your neighbour's car that was parked out the front.
bahaha!
yea finally got it on the road in june, i took the route into your street not too long along just to double check that you still have ur ceffy
spotted a black stock ceffy on stud rd in rowvile a few months back, spotted that white uras kitted ceffy for the 3rd time
also met paul's (Lryder) mate that just got his ceffy on the road.
so shan have you got your ceffy going again?
still runs like a bitch though, the CAM timing's off so it splutters and chokes. Need to get it to a mechanic to get it sorted. Actually might do that next weekend.
If I fix it, I'll sell it tho lol cos I've got too many cars now.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
