Im going to buy some adjustable cam gears for me GTR and was wondering why i would pay $500 for tomei cam geasr when i could buy JJR cam gears for around $249 the pair???
Whats the differance between the two etc etc???
i am using a pair i got off ebay (not the jjr ones) and found that when they heat up that it is very hard to adjust them as the inner alloy must expand slightly cause them to jam. Made it hard to adjust them when on the dyno.
OK this may not be an issue with JJR ones (ive never used them) BUT with various aftermarket cam gears i have used over the past year or so i have found MOST are not true to the timing marks.. ie zero is far from being actual zero... in once instance the gears were close to 10 degrees off.... This is a real pain especially if you have a recipe that works and pre set them.... this engine with the real bad gears lost 15rwkw str8 away up top and quite a bit more through the mid, we had to diagnose the problem on a dyno and re set them to get the most from the combo and the money saved from the cheap gears was less than the extra dyno time to find the new optimal gear settings.
Best bet is to buy them and expect the worst, and time the engine to make 100% sure your cam timing is where you want it... For me this now means i charge more to install no-name gears as i have to determine accuracy before it leaves the garage.
yes plz pm me... but by the sounds of it i should save the extra cash and by decent ones... that saying have you ever had trouble with brand name ones???
Is it worth getting them now, with the standered cams and computer?
Just get the factory ones modified.
Cheaper again, and perfectly fine. Plenty of people have done it and then you get no issues with wear, no timing issues and KNOW they will be right.
Yer X2 now we know what are S**T quality whats the BEST
The HKS early pulleys were not sufficiently hardened, teeth wear was obvious after as little as 5,000 k's. So simply going on brand name alone is not always a good idea. We use Jun, never had a problem, so I haven't bothered to change.
Cheers
Gary
What are JUN GTR ones roughly worth?
GREDDY
TOMEI
new HKS are all fine.
the jun ones are pretty cheap too rrp 16000 yen (RRP $175ea) but can be got easily for alot less.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
    • It’s an rb25 so a gtst and I’ll get that valve
    • Thank you for this my turbo doesn’t have the nipple so I’ll get one installed in the turbo to Intercooler piping. I’ll get everything I need and locate it all using the information you both gave and get back with an update.
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
