Why not leave the stockers on for the first few 1000km while you get the whole setup run in and sorted, only run 7psi then when you can afford it get some bolt on upgrades and wind some boost into her.
Its a daily car. I dont want to blow any more money on serious bolt ons, the engine building took up more then enough money. Going with insane bolt ons is just stupid on this daily car.
DP03 mentioned 2530s ? Wouldnt that still be too responsive on a 3L ?
The way i see it, i dont want to make more then lets say ~270rwkw, and i was thinking of incorporating a twin turbo set up that uses stock turbos x 2 (gtst/wrx etc) which are cheap to replace. If i can have twin td04's and i can push ~14psi through them safely, i would be more then happy.(if this works out to be a good/cheap option).
Also to answer 1 of the previous questions, why high/low boost setting. Again, its a daily car, why would i want to run 14psi constantly in city driving ? Leave it at roughly 9psi day to day, wind up to 14 for fun times.
All this is still in the planing stages so any more turbo setup suggestions are more then welcome !
edit: TD04's are Mitsi turbos ? are these IDENTICAL in every way with the ones the WRX use ?
https://www.sau.com.au/forums/topic/204026-rb30dett/page/2/#findComment-3620397
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
