Hi,
***EDIT***
I have noticed a leak from my power steering rack from the top of the pinion housing. I have looked in a workshop manual for Aussie 31, and it seems that there is a cover, then a seal - I assume mine is rooted. Has anyone had this problem and fixed it? Does anyone know if the steering shaft comes away easily from the pinion housing?
Thanks,
Old topic -
I can't stop a power steering leak on my R32 GTS4. The leak is coming from the banjo fitting on the steering rack that connects all the way back up to the resevoir. I have tried to replace the washers that came out of there (there was one each side of the fitting), however this has proven difficult.
he washers that came out were brass with a slim rubber ring on the inside of each. They looked abit average as the rubber ring was not even the whole way around.
I went to Pirtek to get some new ones, however the outside diameter of the washer was a bit larger meaning that the washer doesn't sit flush (the easher actually sits in a slight groove on the steering rack).
I the got some new washers from Nissan which were the correct size, but did not have the rubber ring on the inside.
Anyone had exprience with this? What was the result?
Edited by Birth
I haven't looked at a gts4 but the gtr washers are just straight copper washers no rubber seal. the copper itself is soft and forms the seal as long as it is clean. Are you sure the original had rubber seals?
I took another look at it and found that it is not leaking from the washers, it is leaking from the top of the pinion housing where the steering staft joins the rack. Are there any threads around that go through the repair of this?
  • 11 months later...
    • Wanting to avoid this if possible but kinda looking like I may not have a choice 😭
    • Ok awesome thank you. Just wanted to have them in case I can find some and need to compare part numbers!
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
