Hey
i bought a C210 skyline for 2.5K its painted black via can but good job, and its got 60K on the clock motor runs absolutly flawless same as trans and diff
ive just got 2 problems i had a mechanic drive the car when i was purchsing it and he said the gear box mount and a UNI joint is on the way out i cant notice it
was wondering is it a must to fix ?
https://www.sau.com.au/forums/topic/204066-c210/
Hi,
Why wouldn't you fix it? It's none to difficult to pull out and swap the complete driveshaft and universal joint assembly and the crossmember. You don't want your drivetrain slopping around too much.
Is this the car that was advertised in the for sale forum?
Anyway - nice work finding a C210 that requires so little sorting out. Put a pic up for me if you get a chance.
Cheers,
Drew
https://www.sau.com.au/forums/topic/204066-c210/#findComment-3618029
nah wasnt in the forum, will get more pics was planning on touching up the paint job a bit and stereo over this weekend but cant grr
http://img170.imageshack.us/my.php?image=rearendgy9.jpg
http://img222.imageshack.us/my.php?image=frontvn5.jpg
reason why im hesitant is due to i got no cash at all
but how much would a Uni joint be and gear box mount ?
https://www.sau.com.au/forums/topic/204066-c210/#findComment-3618098
Ok, The driveshaft and crossmember should be cheap enough, but there are two problems though: postage costs and the unavailability of new parts. The second-hand stuff that you get from may be no better than what's already on the car. I live in Melbourne and can help you find the bits you need if you get really stuck.
If you have no cash today at least sand/grind the rust out of you bonnet pronto. Hit every panel and your doors with a can of fish oil. Your car is nice and straight but the rust is going to hurt your feelings unless you get on top of it quickly. It's probably more urgent than the mechanical issues.
Good luck with it.
D
https://www.sau.com.au/forums/topic/204066-c210/#findComment-3618378
The Uni joint isn't sealed, it's the big knuckle coming out either side of your diff. I wouldn't grease it. There can't be more that 0.01mm of play in the joint, so if there is any movement in it at all it should be replaced.
Rust is often worst in the front of the bonnet under the piece of trim, and hidden in the rubber strips that run along the bumper bars...
https://www.sau.com.au/forums/topic/204066-c210/#findComment-3619087
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
