Off the shelf from Garrett it doesn't exist . The only ones I've seen pics from are in the US and they use Garrett T04 turbine housings .
Geoff Raicer sells a Turbonetics Twin Scroll version which is based on a larger cartridge than Garretts GT3582R .
Which manifold do you have ?
Cheers A .
https://www.sau.com.au/forums/topic/204080-gt3540-t4/#findComment-3618217
x-force apparently, its off ebay. its pretty good quality, better then i expected. all from stainless
change the flange T4- T3 i have seen a few done real nicely at CREATD.... but the fact a decent T3 manifold was nearly impossible to get i had ours made OS
https://www.sau.com.au/forums/topic/204080-gt3540-t4/#findComment-3621333
    • Sorry I think that must be another language thing, globe = light bulb
    • Man, you guys are like an all knowing encyclopedia.. how do you guys know how to fix everything?? but thanks. i will try to trace this wiring today. What is this globe thing you are referring too? Globe Power Supply? Are you referring to the light bulb?
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
