Intake Plenum Question - Dropping Boost - Also Good Tools To Have When Owning Skyline For $29 !
Made mine up using a piece of metal tubing the same size as my inlet pipe. Simply welded a cap on it and fitted a tubeless tyre valve.
We have pressure tested 4 lines with it to date, 2 with known boost leak probs which we found and fixed and 2 with the owners claiming no leaks. Both of these tests revealed multiple boost leaks.
Its a very worthy excercise imo.
Nice work fineline. Where were the main boost leaks? So you attached the inlet pipe you made to the trubo inlet hose? So you are effectively pressuring up through the compressor side of turbo?
Cheers
Edited by benl1981
So Adriano, do you think wack the old gasket back in with some goo? I can't see any holes in it. Anyone got any ideas from the photos?
Use HYLOMAR spray.... it is god on metal gaskets.
Well after adding gasket goo (to intake plenum gasket) and blocking BOV I am still getting huge boost loss after 5500-6000rpm. I am just dropping my cat to see if it looks collapsed. There is no evidence of leaking at the plenum gasket now so I think that's sealed.
I will make the pressure tester and check the inlet tract.
Only other thing I can think of is weak valve springs but you wouldnt think that would change in a week!?
I guess my centre muffler could have issues.
**PROBLEM SOLVED*** modified stock snorkel not allowing enough airflow or sticking to bonnet
Edited by benl1981
Hey fineline. What about the hose that takes the blow by from the rocker cover? That is connected to the rubber intake pipe. Should you block that so you dont pressurise the top half of the engine?
Cheers
    • So, good news and bad news Bad news first: The intake plenum is lost in the mail apparently, I haven't paid for it yet, and MX5 Mania are still chasing it up, farking 'Merica postal service  Good news: Any retune will be free if and when it turns up,  I'm still keen for them to throw it on The car goes noticeably better, with only the typical initial take off thingie from a choppy cam and manual transmission, but giving it just a little more RPM than before gives it a smooth take off (and hour or so of peak hour traffic sorted that little skill out) Car made around 145kwatw & 225Nm (Intake may get me to 150kw, maybe....馃ぃ) Weirdly, 145kwatw is the same max power that my standard 2015 WRX STI made a few years ago The cam really comes alive from around 3.5k and keeps making power and holds it flatish all the way to 7k, whereas before torque would drop hard around at 4.5k Drive home was sadly in peak hour, although I did get a little clean air here and there to wind out 1st and 2nd a little bit, and whilst the gains aren't anything for the "boosted boys" to be impressed at, the thing is a blast to drive The sound in the vid is poor, as it is in a undercover yard at work, but, outside, in the wild, it sounds awesomeballs to my ears with all the choppyness I consider it money very well spent for the outcome  Cam specs for reference (Basically the biggest you can fit with stock pistons) 20250417_171807.mp4   LOL, I don't think I will ever grow up
    • Swap the injectors around and see what happens. If the misfire follows the injectors then that's a signal, if it doesn't it's probably not the injectors.
    • R33 with RB26 seems to go off of learned voltage for idle. Seemed like whatever the baseline voltage was once ECU first gains power will be the idle voltage. With ignition on unplug/replugging the TPS would relearn the idle TPS voltage.
    • Have you confirmed the 2 pin coolant temp sensor on the motor is working properly? I've had a very similar issue when I forgot to plug mine back in many years ago.
    • Ok interesting i guess ill wait till using a manual gauge before making assumptions.
