well thats good, i would sugged you get the sensor bung welded in before you go to get accurate readings, they cost around $5 each or less and its about $20 to get it installed at any exaust shop, if you go into the shop and tell them what you want they will be able to order it in and fit it for you.
Hi mate
can u clar this thing up for me again? i'll go to my local exhaust shop to get it done before i'll go for dyno run again.. and where should i get that sensor bung welded in to make it easy for dyno operator?
cheers
just go to the exaust shop and tell them you want a sensor bung installed, you want it around 20cm's before your cat, no closer if posisble
Hi mate
cheers
