Hey guys,
just seeing
1) who might be interested in a group buy on O2 sensor's
2) is there a difference between R32 33 and 34
3) how much should i ask for them I'm thinking roughly 10 units @ $90-100
also my exhaust place says its (from memory) called trident?? and he claims there better than the NGK ones
discuss
*****GROUP BUY OPEN*****
part NGK R33 o2 sensor also fits R32 but not R34 im looking into what the R34 is
Price $61.60inc.
even if you've already stated you might like one please register your intent on purchasing one and i will pm you bank details and add you to the list
i will limit this group buy to 10 people @ 2 weeks from today's day and i will make it all payments in by Friday 21st February, if there is a lot of people wanting o2 sensors i will make a GB #2
thank you
1. Madaz
2. darkhorse
3. bundy_bowler
4. R334door(s2)
5.
6.
7.
8.
9.
10.
https://www.sau.com.au/forums/topic/204186-group-buy-open-r33-o2-sensors/
  • Replies 64
interesting would that be the xr6 turbo one or just any old falcon one?
ford one's can be used they are around 50 bucks new.
ah ok , well lets see where all this talk leads us ill ring the guy who will talk to the supplier for us on monday
well, i have 1 thats working fine, 1 thats on the blink.... =P hence, only need 1 (i thinks)
before you all go rushing out to buy an o2 sensor (btw i dont have your otherone steve) you can test it easily to see if it works or not.... if it works no point wasting your cash and replacing it since your going to be 60 bucks down and have the same economy to show for it.
grab a multimeter and start the car when its at operating temp... probe each of the 3 wires til you find the signal wire (i think its the middle one, could be wrong) and the signal wire should vary between 0.1 and 0.9 volts continuously at idle. if it just stays on a figure... its stuffed
this is the perfect thread for me.....i was just going to ask if anyone knew how to test for a O2 sensor....well thanks to simon now i know what to do and what to look forward to......
quick question
my car has a stock ecu, afm, fuel pump and all.....and its running hell rich just wondering what could i do to not have it running so rich....from what i have heard is that stock r33 ECU's cannot be tunned so how would they make it not run so damn rich.....
This is the NGK part number for the O2 Sensor:
OZA395-E2
I know the R32 and R33 are the same but i am not sure about the 34 as i have not had to replace mine as yet.
I think that Steve and i are going to pull our O2 sensors off and see if they are the same.
All well & good using the Ford sensor if it's the same wire configuration & range. You do have to be careful how you set them up though.
To adapt the Ford sensor to the original connector, all terminals should be crimped using heavy duty connections NOT soldered. Then the crimps should be wrapped in something like a heat resistant vulcanising tape.
If you solder wires you risk having issues with readings later on when the joints fail, & they will fail. Additionally soldering alters the voltages on what is a very sensitive piece of equipment. It only takes small variations with an O2 sensor for the ecu to interpret things quite differently.
While testing with a Multimeter is good for a basic functional test, I wouldn't be willing to bet my life that it's working 100%. O2 sensors do deteriorate with age & use. After only about 60,000km's mine was stuffed, & it never worked as good as it should from the moment I had the car at only half those kays.
Madaz, if you're looking for a supplier I know someone that may be able to get you a pretty good price for a group in either Bosch or NTK (otherwise known as NGK when it comes to spark plugs). The Bosch ones are quite expensive.
I personally run an NTK sensor in mine on the stock ECU & it runs really sweet, with good power & economy.
Edited by J_Red33
    • At least you're now aware of the problem and can come up with a solution.
    • Dang. Keen for further updates when you get to it.
    • Welcome to SAU Thomas, sounds like you'd had a bit of a an unlucky start with the car, hopefully you get some better luck now!
    • 1. No need, it only gets used once then is locked in place by the nut 2. EN-62 point 6 shows the conical washer the other way around (BTW I know we discussed above, I hope you are changing the idler as well, while it is no guarantee the bearing is a actually bad, it looks terrible) 3. I'm not really clear on the question, are you worried because it was easy, not hard, to remove the custom timing trigger? As long as it doesn't spin on the crank (when the bolt is tight) all good 4. Yeah just make sure the brand is easy to read as it rolls past 5. The part number is on the listing under the description, 13023-42L00. Given there is a custom part on there for timing (presumably outside the cover), they may have decided to leave that off; I think I would put the washer in there as it also helps seal the timing case from crap getting in.
    • Hey everyone, I recently bought myself a 2001 Nissan Stegea M35, and I've had a few issues that I had to fix, my car would start intermittently and I had a bad rocker cover leak, after a couple days of looking I finally found a part number that interchanges with the OEM starter as the OEM starters at $1300 and I can't afford that, this starter was only $270 and I replaced the start and still had the same issues, I posted a video asking for help online and it went very well, some guy said it was probably a bad ignition switch so I took my dash apart and turns out my ignition switch was half screwed in and was loose, once it was tightened it fired right up, I found a local place called "Boost factory" and they sold me a part of OEM Nissan rocker covers, they were $600 which was a shocker but I couldn't find them anywhere else, so I installed them and fixed my oil leak as the old rocker cover was cracked and warped, I now need to replace my boost air inlet hoses as they have some cracks.
