  • Replies 64
Hey guys,
just seeing
1) who might be interested in a group buy on O2 sensor's
2) is there a difference between R32 33 and 34
3) how much should i ask for them I'm thinking roughly 10 units @ $90-100
also my exhaust place says its (from memory) called trident?? and he claims there better than the NGK ones
discuss
*****GROUP BUY OPEN*****
part NGK R33 o2 sensor also fits R32 but not R34 im looking into what the R34 is
Price $61.60inc.
even if you've already stated you might like one please register your intent on purchasing one and i will pm you bank details and add you to the list
i will limit this group buy to 10 people @ 2 weeks from today's day and i will make it all payments in by Friday 21st February, if there is a lot of people wanting o2 sensors i will make a GB #2
thank you
1. Madaz
2. darkhorse
3. bundy_bowler
4.
5.
6.
7.
8.
9.
10.
my name is not down yet is this still going ahead?
this is still open im debating whether or not to add it to the main GB section but havnt had a chance to cost how much to do next day shipping and find a price on R32 sensor if the R33 one really doesnt fit /looks @ Cubes
dont loose hope guys just been flat out @ work lately so until i can get extra info i may just hold off on closing the group buy, just didnt want it run like the last one
when i have more new i will update as required
cool thanks for update steve
hey Allan i notice you were also on the 300kph speedo group buy has yours warped @ all
no it hasnt i was reading ur post about ur's have warped i left my car out in that heat wave we had a while back and its still good dunno mate did you stick em on or?
I'm keen for 1x O2 sensor. Put me down.
Is there any warranty? I bought one from an ebay store which failed after a couple of weeks - they said it had a 12 month warranty, but i never got around to sending it back for testing.
Edited by Trav33
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
