  • Replies 51
Yes camber is the key, I have camber on the rears but only due to the lowering, how quickly do you go through tyres, I was basically planning on getting smaller tyres.
I have not hit front or rears except for big mups since rolling the rears and taking the liners off the front and bending the tabs up.
How much were your adjustale camber arms ? for the rears
Nice car to mate, does anyone know if you need to cover the small wiring under the left hand front liners ?
Nice car to mate.
I am going to take the rims off this weekend and put the stockers back on, then leave them off until i get a good solution.
Just not sure what that is these are my options I think:
1-Camber with exisiting rear tyres but they will wear out quickly
2-Smaller tyres 235 or 245.
3-Both of the above
4-Buy a Nissan pulsar and have an easy automotove life lol
Edited by Mark0
not reading whole thread so dont know if this has been said or if u sorted it. Get castor rods and put more castor on. That will move your front tyres forward. Making for better handling and no scrubbing. And get coilovers if u dont have them, car might not aborb bumps so much and wont scrub casue will be stiffer
I have the white line camber kit on mine ( front & rear) didn't need to go adjustable camber arms. Depends on how much you drive. if you do about 15000k's a year then that should be ok, my car is only a weekend warrior so doesn't bother me. i wouldn't worry about it rubbing the guard liner so much, they are flexible and won't do any damage to the tyres.
Having castor on the front will help turn in, however your front tyres will rub under full lock. i just got a heat gun and moulded the liner (when its hot) to accommodate for the rubbing & worked a treat
Yer I have tein Super Street coil overs, Think I will go changing the tyres options, Camber arms fitted will cost me about 395 but I think I would need a lot of camber to get them under my gaurds, thus increasing tyre wear pretty badly
I am still undsecided what to do, is the law on the wheel under the rime that it needs to be under the top of the guard only ? My mate at Bearepairs said the law now is that the tyre needs to be under the guard not the rim, either way I might post a pic of the amount it sticks out and see if you guys think that camber is the way to go or if ity would require to much camber.
How quickly do you go through a set of rear tyres n1
  • 5 years later...
if its only the plastics cut them back, i did that for mine (r33 GTST)... better
flairing and pumping of guards are expensive, rolling of the guards just end up a mess, you will end up in tears
i've just lowered my coilovers (90mm ground to chassis) but the front tyres are scrubbing the guards, do the plastic linings of the guards do much or will it not matter if i take them off?
I'm pretty much the same, I have 17x10 RPF1's +18 and 275/40/17's on the back and the inner guard lip does cut into the side wall of the tyre if i have passengers in the back or hard cornering at the track.
Recommendation Sydney Area :- "Sydney Guard Rolling"
Proprietor :- Nelson
Work Done :- Flaring/Pumping/Rolling
Convenience:- Mobile Service
Contact :- 0432109331
Referred to Me By:- Wholesale Suspension
My Story:- My 'new' EVO has had new 8.75" wide rims with new RE002 rubber put on > scrubbing at the rears with the guard lips cutting into the tyres' side walls whenever I have passengers.
Nelson got to my place by 3.50pm and worked on these guards by attaching a hub bracket and carefully applying a roller.
He was very very patient due to his concern over the likelihood of cracking paint (due to previous nicki applied).
Nelson worked on it till sundown > no cracked paint > cost was $150 > terry - happy
That's definitely some useful information there. This is someone who takes pride in his work and it shows. Thanks Terry for the info and hats off to Nelson :)
    • I'm thinking that this is such a small part of the problem that you could easily forego the vac pump and just achieve 90% of what you need, which is keeping the gate open when off boost. It's not as if there are not already techniques to keep a gate fully closed under boost. After all, you have boost. Just use a wastegate actuator that will allow you to apply the boost on the appropriate side, just like every external gate out there.
    • Heres another fitment photo. redrilled the pattern to 5x112, and threw my audi´s rims on. had to touch the upper control arms with grinder, because the "sharp corner" was sticking about 2-3mm on the tire path. i have the "fender lip" mostly cut off, otherwise these (too) would contact with it. 20x9.5 ET25 rear    265/30 20x8.5 ET20 front    255/30 they are temporary, and look too big for the chassis. searching for 19s to it.
    • From experience, it will come back to bite you haha.
    • Background: my BMW 225i hatchback (rebodied MINI/X1) came with 3x RE003 and 1x Goodyear Asymmetric something. The RE003 roared and slid around, the Goodyear side was quiet and grippy. Definitely my car was thrashed before it got sent to dealers. My brother also got RE003 all round on his old VA WRX STI, I wasn't impressed with them, car was loud so can't comment on noise. Anyway, Hankook stopped making/updating V12 Evo2. So bought S1 Evo3 runflats. Great daily duties tyre and not that harsh ride. Tyre reviews site/youtube rated them as best stopping in the rain and I believe them. Next set, Goodyear Asymmetric 5 non-RFT. It beat PS4 in tests and is like $100 cheaper, so put them on. Great tyre, more grip then S1 Evo3 but a tad noisier as expected, still rocking them. Next set I am looking to go runflats, probably the new Hankook Evo. Although the new Pirelli PZ5 did well in tyrereviews test. Or go Goodyear Asymmetric 6 which was top tyre last year. The V12 Evo2 on my gen5 Liberty GT wagon did great in cold condition (drove to snowy mountains for a day so my husky can feel his ancestor's roots). Super impressive performance for $120 each lol. Never skimp on tyres, brakes, suspension. There's old pics of my R31's crappy random brake pads bending in the caliper at Oran Park track day somewhere around here. Anyway, my 2 cents.
