  • Replies 51
Yes camber is the key, I have camber on the rears but only due to the lowering, how quickly do you go through tyres, I was basically planning on getting smaller tyres.
I have not hit front or rears except for big mups since rolling the rears and taking the liners off the front and bending the tabs up.
How much were your adjustale camber arms ? for the rears
Nice car to mate, does anyone know if you need to cover the small wiring under the left hand front liners ?
Nice car to mate.
I am going to take the rims off this weekend and put the stockers back on, then leave them off until i get a good solution.
Just not sure what that is these are my options I think:
1-Camber with exisiting rear tyres but they will wear out quickly
2-Smaller tyres 235 or 245.
3-Both of the above
4-Buy a Nissan pulsar and have an easy automotove life lol
Edited by Mark0
not reading whole thread so dont know if this has been said or if u sorted it. Get castor rods and put more castor on. That will move your front tyres forward. Making for better handling and no scrubbing. And get coilovers if u dont have them, car might not aborb bumps so much and wont scrub casue will be stiffer
I have the white line camber kit on mine ( front & rear) didn't need to go adjustable camber arms. Depends on how much you drive. if you do about 15000k's a year then that should be ok, my car is only a weekend warrior so doesn't bother me. i wouldn't worry about it rubbing the guard liner so much, they are flexible and won't do any damage to the tyres.
Having castor on the front will help turn in, however your front tyres will rub under full lock. i just got a heat gun and moulded the liner (when its hot) to accommodate for the rubbing & worked a treat
Yer I have tein Super Street coil overs, Think I will go changing the tyres options, Camber arms fitted will cost me about 395 but I think I would need a lot of camber to get them under my gaurds, thus increasing tyre wear pretty badly
I am still undsecided what to do, is the law on the wheel under the rime that it needs to be under the top of the guard only ? My mate at Bearepairs said the law now is that the tyre needs to be under the guard not the rim, either way I might post a pic of the amount it sticks out and see if you guys think that camber is the way to go or if ity would require to much camber.
How quickly do you go through a set of rear tyres n1
  • 5 years later...
if its only the plastics cut them back, i did that for mine (r33 GTST)... better
flairing and pumping of guards are expensive, rolling of the guards just end up a mess, you will end up in tears
i've just lowered my coilovers (90mm ground to chassis) but the front tyres are scrubbing the guards, do the plastic linings of the guards do much or will it not matter if i take them off?
I'm pretty much the same, I have 17x10 RPF1's +18 and 275/40/17's on the back and the inner guard lip does cut into the side wall of the tyre if i have passengers in the back or hard cornering at the track.
Recommendation Sydney Area :- "Sydney Guard Rolling"
Proprietor :- Nelson
Work Done :- Flaring/Pumping/Rolling
Convenience:- Mobile Service
Contact :- 0432109331
Referred to Me By:- Wholesale Suspension
My Story:- My 'new' EVO has had new 8.75" wide rims with new RE002 rubber put on > scrubbing at the rears with the guard lips cutting into the tyres' side walls whenever I have passengers.
Nelson got to my place by 3.50pm and worked on these guards by attaching a hub bracket and carefully applying a roller.
He was very very patient due to his concern over the likelihood of cracking paint (due to previous nicki applied).
Nelson worked on it till sundown > no cracked paint > cost was $150 > terry - happy
That's definitely some useful information there. This is someone who takes pride in his work and it shows. Thanks Terry for the info and hats off to Nelson :)
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
