Hey guys
I have just recently bought myself an R33, with a MFIC ... pod filter and big exhaust .. the usual mods .. when i took the car for a test drive it the car yard was asking how it idled .. aparently it had an issue .. i never had problems ... and it had a dodgy battery which needed replacing.
i got the car .. drove it home and it was fine, i changed the battery put a new one in it .. and then all my issues started it wont idle at all, go for a drive and when slowing down it wants to come to a stall .. or it will idle very low and then come to the verge of stalling.
I fiddled with the IAC and the throttle position sensor to get it right .. set it to a good idle ... rev it and it all runs fine .. take it for a drive .. and it will either run fine for a moment .. till i turn the car off .. or run like s**t. I took it to a skyline specialist here in perth .. and he set the idle for a high idle .. and told me my BOV was leaking .. i fixed that issue .. set the idle back and still wont idle properly.
have been over everything .. and have no idea what to fix it ... could i have an AFM issue .. a computer issue ( i mean as it was fine till i changed the battery and rang like s**t after the new battery went in it ) or an throttle position switch issue
if you can help me out and give me some tips or opinions it would be helpful
Cheers guys
https://www.sau.com.au/forums/topic/204200-idle-issues-need-help/
  • 3 weeks later...
mate i have the same problem, when its cold its good to idle and sart, but when it warms up it goes to 900 then drops to 50 -100 and sometimes stalls.
what do you think is wrong?
i have just replace the tps in it
This may sound strange but our R33 (sII) was idling at 1500rpm and we couldnt figure out why, firstly we got some carby cleaner as the throttle body was gummed up with carbon, then by chance we pulled out the idle stepper motor to find a piece of our impeller blade (we blew out the stock turbo 2 weeks earlier...) was not letting the plunger motor sit on its seat, so after we cleaned that out too and put her back together she was fine....
Hope u find out wats wrong with yours!!!!
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
