hey, ive im wonder is there a good way of hooking up a boost controller..
like ive got mine hooked up
but i wana check if the set-up is correct..
so, im just wondering if u hook-up the hoses backwards, or have the hoses too long, or short, wer you connect the vac. hoses too would make any difference???
http://www.autospeed.com/cms/A_2687/article.html
the article above is the type of controller i have...
so any ideas would be great... :banana:
hey man.
there is 1 there is 1 way and 1 way only to hook up a bleed off valve. if u have it on backwards you'll know :)
the review on it looks sweet tho. the hose length wont matter im sure but id keep it roughly the same length as the original hose (same length with controller in middle).
Hoses too short wont matter, just dont try to cabin mount these or you will get boost spike. just make sure you use big enough diameter Vac hose, and make sure its the right way around or it will overboost and possibly blow the turbo. Once its in, just turn it up a small amount at a time, as these controllers a quite sensitive.
