the best possible thing to run that screen is...
garmin GVN-52
do a google search on it - its a fantastic nav unit and would work like a pimp on the factory screen via an aux inpot
chris rogers will sort you out: www.audioexpress.com.au
so your saying it has same dimensions and can still fold up and down electronically like the current factory one does? cause im not sure it will fit by the looks...it looks great though, i really wish someone had a solution in victoria regions...gah...even the guys at alpine couldnt help they said it can be done but blowing the tv in it can be very likely down the track. son of a ...
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
