long story short i cant decide on a plenum choice. because im a total shit f*k wen it does come to anything liek this crap.
so i came on to trustly sau for more info
basicly from my shit research its come down to 2 choices
modify r34gtr greddy plenum (or ecr33 plenum)
or go bolt on with plazmamans plenums.
as i pretty much know nothing about plenums i thought i would ask others out there who went on a simliar approch.
i understand that plenum sizes take are directly related to lag?
also what recommended throttle body size should i be looking at.
cheers
https://www.sau.com.au/forums/topic/204227-plenum-choice/
I would do what I did and nomuken does. Use a RB26 throtle bodies and plenium. Race Pace make the adapter plate. All you need to do is buy the RB26 intake side $400 - $600 and the go to race pace and get them to install it.
It is extramly responsive and the japs claim a 40hp increase straight up. I would only go Gready if you were making a 600HP drag car. Plus the single throtle body is a bit mushy but has good flow up top in big hp aplications.
Race Pace 03 9762 9421
https://www.sau.com.au/forums/topic/204227-plenum-choice/#findComment-3620252
sweet.... that is the perfect solution (i just though it was no longer viable as the jap ones are NLA or incomplete), as discussed much previously.
im glad RACEPACE made it i will cerainly start spreading the word.. after selling the last one to you i have had enquiries from every corner of the globe and had only bad news to tell them :)
and yes on std Rb25 with usual bolt ons expect a 40hp increase EVERYWHERE.
https://www.sau.com.au/forums/topic/204227-plenum-choice/#findComment-3620275
couple of weeks back i was talkn to ben at racepace about jsut dropping a complete 26 head onto the rb30 and using the standard plenum.
but i understand theres alot of things i need that would be missing?
URAS would u know apart from a complete head, plenum, throttles, manifolds and turbos, what i would be missing to complete the transfer?
wiring loom, ecu? ect
https://www.sau.com.au/forums/topic/204227-plenum-choice/#findComment-3620284
  • 3 weeks later...
    • Ha ha, ended up going it alone.  I just sent it (in a very nervous fashion).  Once I'd released the locks and it didn't automatically start spinning out of control i felt a bit more confident.   It made some loud sounds (cracking and creaking noises) when I first spun it which got the heart rate going again!  I couldn't bring myself to leave it tipped on the side.  I feel a bit more comfortable having back right side up while it sits there. I'd get angry with your last point but you're 100% correct! 😅 Even yesterday I managed to distract myself at numerous times to make a bracket to fit an LED flood light off the back of the house and fix my sons pushbike.  There were other little taks nibbling at my brain for the rest of the day too...
    • Probably one of the more nerve wracking experiences of my entire life! 😂😂 The balance (centre of gravity) is out still but in a direction that gives me comfort!   It's quite bottom heavy still meaning it takes a bit of muscle to rotate it.  The plus side of that is that it wants to to go back to upright.  Better that than wanting to go all stranded turtle on me!
    • hmmm that's not ideal. This is a pretty new engine right, will be interesting if your engine guy has any theories about causes
    • A universal ball joint removal c press kit is better money spent and will work for the Hicas ball joints.  Here's a 45$ CAD Example. ATPEAM Heavy Duty Ball Joint Press Kit with 4WD Adapters | Professional 4 in 1 Ball Joint Press Removal and Installation Tool for Cars and Trucks | Universal Ball Joint Tool with Storage Case, Ball Joint & Tie Rod Tools - Amazon Canada
    • True on both points
