Did you bed it in properly?
Try Pete at AFAS on 9723 5955, they are KAAZ dealers.
It was installed by a mechanic, along with new timign belt and stuff. So im not sure if the figure 8s etc were done. I assume they were as the mechanic knows more then me and its on the install instructions. I have done about 8,000kms on it, a few track days and motorkhanas, and changed the fluid at about 2,000kms.
I will give Pete a call on Monday. Thanks
Troy i have the KAAZ in mine. The mechanic (who ever they may) most probably would not have done the fig 8's. It's easy to do, but you need to have some open space, and 20min. Not sure if it's too late to do now, but it wont hurt.
Also what oil are you using? I have changed the oil in my diff twice now (since the KAAZ install) and each time it has gotten better. The next and final oil change, i'll be using Castrol oil, need to speak to Pete (Bass Junky) to see what type. Even with the current oil i don't feel mine as being that bad.
I havnt got mine back from having it installed...see if I have simiraly issues this week. Although my guys were pretty clued in to giving me the right setup. I bought mine 8 months ago but if I had my time over I would have got a NISMO 1.5way which you can more easily adjust pre-load etc.
let us know how u go, I'II give my feedback on my setup next week.
Check your tyres carefully - us drifters constantly have problems with shit tyres and mechanical diffs - best thing is to find another good pair of wheels, put em on the back and go for a drive - even if your existing tyres look PERFECT.
If not brisby - throw it out and weld the stock one :)
I have since run the run in procedure myself, but it is probably a matter of too little too late. Also i doubt its the diff itself or the install. Most likeyl just the fact that everything in my driveline is shagged. So need to give it to a driveline specialist to get it all tidied up and dirivn without all the clacking, backlash...its horrible :)
And Al, this is th eonly fluid i have used in my diff for years... http://www.castrol.com/liveassets/bp_inter...rans_B13127.pdf
I now find myself using Castrol engine oil, brake fluid, gearbox oil and diff oil ;) Its flat out the best in my eyes
Syntrans is GL4 rated and good gear oil. go a GL5 Synstrx if your serious IMO but they are both good gear oils.
I now find myself using Castrol engine oil, brake fluid, gearbox oil and diff oil :) Its flat out the best in my eyes
You should try Castrol SAF-XA http://www.castrol.com/liveassets/bp_inter...XA_B1769_04.doc.
I haven't tried it myself yet, but i've heard good things about it.
Brisby, try Matt @ Total Traction in Moorabbin, he installed acsplits KAAZ and yes it has been mickey mouse. The only issue I am aware of that he had related to the actual diff housing with fluid leak from a seal. He did a really good run in on the diff, way more than 20 minutes from what I gather and it has been perfect. Likewise, cazz from R31 clubs diff has had the noises, but never got a massive run in. Speak to Matt and see what he says, he is generally very cluey and may have some suggestions for you aswell as any other shop that deals with KAAZ diffs.
Oops. I posted the wrong link. That is what i use in the diff
http://www.castrol.com/liveassets/bp_inter...a/AU_SAF_XA.pdf
Syntrans is what i use in my gearbox. And thanks Syphon, will give them a phone call as well.
thats a good GL5 rated gear oil. Their add. package is good for lsd's not too slipperly.
Chris until you bed it in properly, change the oil every 1000km for the first two oil changes, the diff will be very clunky, especially for the first 1000km.
my diff has been in for about 1 week. They did some figure 8s and i did some also...then took it to sanddown for a few laps. Only done about 400km but already its feeling pretty good.
Take it to Le Mans Automotive in Templestowe. Shanes my mechanic there and he owns the place, he rebuilt my diff and its friggin sweet!
Get him to check it out and he will figure out whats wrong with it.
15 Websters Road
Templestowe, VIC, 3106
Telephone: 03 9846 2761
Edited by (00)SKYLINE(00)
there's a great place on cooper st just near thomastown i think it is
ill find the name - they pulled apart my active lsd and tried to diag / work out why it was being homo
nothern differentials - these guys as posted above
Address
47 Cooper St
Campbellfield
VIC, 3061
Australia
Get directions
Contact Details
Ph:
(03) 9303 9246
Other:
(03) 9303 9246
Fax:
(03) 9303 9247
* Email business link icon [email protected]
* Email friend link icon Send to a friend
you can also give Preston Autos & Differentials a try.. stan and andrew are pretty good with diff's, they serviced my brothers kaaz 2way and is perfect!
Edited by LTHLRB
Hey troy,
I've got the same diff as you in my 32 and its a clunky backlashy POS...I've changed the oil twice with Castrol SAF-XA and its gotten considerably better...but it doesn't last long...after a few weeks the clunkyness gets worse again...the most recent oil change i've changed i went to Penrite Limslip and it was noticeably quieter than with the SAF-Xa...Try giving that stuff a go...
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.   As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.    I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.   Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.       BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
    • Yeah, I wasn't giving two f**ks for the ring running around the bore. I was looking at the vertical scratches running up and down across the hatch marks.
