Hi,
I've been told that getting a higher flowing cat may assist in getting more power out of my R33 GTR.
It currently has a largish exhaust system I think its 3inch all the way through, and standard turbo's and air intake.
I've noticed that there are a few different cats around there is the X-Force Stainless steel high flow cats from Just Jap for $160
Apparently it can flow 570CFM and it comes with flanges.
There is also a group buy on X-force cats and exhausts
They are 2.5, 3 and 3.5 inch for the "racing" cat I'm not sure if the racing cat is a marketing name or if its race-use only and doesn't comply to the EPA regulations.
And then there is the
Batmbl selling catco cats
There website says:
The prices were:
* 3" large body BOLT ON Catco cat (ceramic inside) - $230 including delivery
* 3" Catco cat BOLT ON (metal inside, 5" round body **not 4" like Magic cat & Metal cat**, 200csi cell - 706.2 CFM!
Which cat should I be using? Will it make much difference to performance?
I'm considering the X-force from JustJap at the moment, it seems to be reasonably priced but I'd like some opinions.
Also, if I get a larger cat will it make any difference to the exhaust volume at all? I assume its very little but....
Regards,
Gareth
Or would it be smarter to save some $$$ and not buy a new cat?
Compliance cats today are usually 3 inch, does it make a difference if I go for a larger cat?
is the complicance cat hi-flowed already?
I got my self a magnaflow hi-flow cat.. Made a fair bit of difference, before i chucked on the rest of the exhaust!!
Otherwise just check which cat is the most flowing..
Edited by siddr20
Hey,
I don't think the compliance cat is high-flowed. If it does make a fair bit of difference I'd change the cat, how much difference are we talking about?
And the larger the cat the more the flow, but will there be any noticeable difference between a cat that flows 570CFM and 706CFM?
I mean I'm not changing the turbo's anytime soon, just aiming to get cat + powerfc + tune.
Regards,
Gareth
hey,
I ended up going for the just jap highflow cat on my 33 GTR. For the power im chasing ~240-260awkw this cat will suffice. Although too be honest, i didnt feel a noticeable difference between my compliance cat, and the highflow. Side by side, there was a noticeable difference in size and restriction, so im sure it made some difference.
Next mod im goin for is front pipes.
Hmm, interesting, I'm not sure if my front pipes are standard or not.
I wonder if anyone has done a before and after run after changing the cat...
hey guys, I got a thread going about going from a gutted cat to a highflow... I really notice a loss of power going from basiclly a straight pipe to an xforce highflow.
Then again, I also noticed a big increase in power from when the cat was normal to gutted.
if you don't have a white car then gutting ur current cat is best for performance. If you do, you will start to notice a yellow tinge to ur rear bar because the cat is not filtering the carbon monoxide.(you have to degs or buff it off each week) bit of a pain really.
those $160 SAU special X-Force cats from JustJaps are shit. I have one in my car and when the exhaust/engine gets hot... I lose 2 PSI of boost.
I use to run a CATCO cat that was welded directly onto my old cat back, noticed heaps more power and no boost drop, since I changed my catback and fitted a new cat I noticed less power and boost drop once the car gets to optimal running temps.
If youve already got a 3" system just keep it, the amount of restriction on it will be neglible unless your running massive hp. Better yet gut it out and bolt it back into place
Great for performance but bad for the environment and a huge fine if you get busted with it in Vic!
And I mean huge...
Then why does a gutted cat allow less restriction and therefore more HP? (either that or a lot of people lie about the HP increase :miner:)
I'm sure people have advised me that it can increase HP even on cars that are not running massive HP.
i have the same problem, except i drive a gtst witha catback exhaust. My next mod upgrade is the front pipe and cat, i was probably going to go with a http://bosimporting.com.au/index.php?page=...t&Itemid=27 and the batmbl split dump. Should i go with that cat or get soemthing more expensive? Street use only.
Step 1: Don't buy beer for 2 weeks.
Step 2: Use afore mentioned money ~500, and use to buy the best metal cat you can. I'd suggest maybe a 4-5 inch depending on your power goals, from S M B
Step 3: Never worry about ur cat again... :miner:
Step 3: Never worry about ur cat again... :D
Haha, ok, no beer until the cat is in :(
I'm going to try to get a 3inch high-flow (probably the x-force racing cat, not the $160 one) that does not have a ceramic inside as its not good for the skylines to have ceramic inside (apparently) :(
Regards,
Gareth
I have a 3" metalcat that has been in service for 12 months. the innards have desintegrated atfer a few track days with a near perfect 12:1 afr. and i am not the only one. i need to buy another cat but may not buy another metal innard cat. once bitten twice shy.
spending $300 on a cat every 12 months is rediculous. going to their website they claim to be the best and say the xforce items are not street legal. I think i am going to go a magnaflow.
I'm going to try to get a 3inch high-flow (probably the x-force racing cat, not the $160 one) that does not have a ceramic inside as its not good for the skylines to have ceramic inside (apparently) :)
Interesting, id like to hear more on this theory :)
    • Oh, that's grim. Something bad has been happening there.
    • Put an endoscope down the hole and saw this. Not quite all around the bore but a good 60% at least. Chin to the chest and towards further disappointments I guess.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
