Hi All, we are temporarily back in Sydney, managed to get the front on and measured the volume. It's about 32 litres. Not sure how long we're around for until we go back out so i'll just keep working on it until we go. Also front is not as big as I originally thought. 12 inch fit's niceley but 15 inch would be a little big. Only way I thought of putting a 15 in would be to extend the mdf front out further into the boot with a spacer. Then again the idea of this is to save boot space, so 12 inch it is for me. Is starting to look really good. will post some pics up if I get a chance to before I go. I bought some black gelcoat for the reproduction boxes so will look even better.
Cheers
Ben
  • Replies 122
Pics are up, still need to sand and polish the original so the mold will be nice and smooth. but this gives a good idea of what to expect. the reproductions will have a black gelcoat shell and will figure out the carpeting.
yeh mate, looks insane, being fibreglass...would these be good to be sprayed? or to have material on? i love the sprayed metallic look, but over-all it looks wicked...
how much would you be asking?
Yes mate..looks awesome...PAT ON THE BACK SON...JOB WELL DONE....
But I guess everybody else would be enquiring about the price for this...i'm sure you'll post it soon...
Oh and yeah...was that a 12" sub installed?
Hi All, yes as Adrian has said it is a 12" in the pics. Thanks mate. Still working on a price, won't decide until I see how long the reproductions take to make and carpeting costs etc. The box could be sprayed but as stated it will have a black gelcoat which should improve the look and I will investigate carpeting it when I get back.This may be the last post from me for a while. Catch up with you all when I get back.
i have done exactly the same thing not long a go and it works well, as i wanted a sound system with a 12' sub and amps in the boot but not loose my spare tyre. ill post up some picture tonight and show you want it looks like.
I've seen this done a few times but looks very neat.
If you do sell them I'll be interested in a couple months time when I get around to getting a sub :D
Hi All, managed to get the mold finished this morning. Once again back for a very limited time in Sydney. Just waiting on the ok from SAU to sell these using the forum and a small donation from each box sold will be given back to SAU. As soon as they give me the go ahead I will give a price. Just to give you an idea the price will be well under that of the commercially available equivalent.
Cheers
Ben
    • Details: Turbo Borg Warner EFR 9180 with 1.05 rear housing Upgraded TurboSmart integrated BOV Sanded and powdercoated compressor cover in gloss black Elbow welded with wiggins clamp Speed Sensor(Not included) (Can include oil drain(heat wrapped + titanium intake pipe with almost new filter for a tad extra). Manifold: 6 Boost RB26/30 twin scroll manifold  e-MAP ports drilled into both scrolls(I was using the TAARKS EMAP KIT) Turbo is in excellent condition. Always used Penrite 15w50 Racing oil(Changed less then 2000ks). Also using the Turbosmart OP regulator and filter. Downpipe: 4inch Stainless steel with VBand inlet and outlet clamps(included) Heat wrapped Dual ports for Dyno/Wideband usage Will throw in free 2.5 inch intercooler pipe(2.5inch From turbo outlet to 3.5 inch intercooler) - Powder coated black. Turbo made 563rwkw on mainline hub dyno at around 24-25psi boost - Pump fuel. Will def make over 600kw on e85. Didn't bother as my e-MAP was through the roof with my setup sitting past the choke line. I have a cnc ported and fully built head on my 3.2. Turbine speed saw max of around 109k rpm. I'm running this on my R32 GTR, with AC, and the original power steering pump. The manifold clears the AC lines, ABS, and everything else. Although I had new AC lines because I just wanted new ones and I heat wrapped them as well. This will make more power on a slightly lower capacity motor with a higher PR. And I have since upgraded to a G45-1500. Have pics and videos if need be.  Absolutely nothing wrong with setup. Turbo is in perfect condition. No shaft play or oil leaks at all. All the work was professionally done. The transient response of this is fkn amazing. I cannot rave more about this turbo. If I wasn't chasing 4 figures, I would have kept it. $5000 NZ. Located: Auckland, New Zealand.
    • I particularly like the look of the John Player Special team. (Thumbnail isn't different but hit play for the clip)
    • Such a cool collection of cars back then.
    • Mystery solved, thanks bro Bit of a strange mix, but i dont mind it, still looks good.
    • nah no problems with bearings or hubs.  just the water pump leak and my AC death
