try the ECR34
or failing that a R34 25GT
Vehicle Specifications
Nissan Skyline R34 25GT
Make Nissan
Model Skyline
Model Variant 25GT
Year 2000 to 2002
Body Type Coupe and Sedan
Seating Capacity 5
Engine Code RB25DE Neo
Engine Type Water cooled Inline 6 cylinder DOHC 24 valve
Engine Size 2.5 litres (2498 cc)
Bore × stroke 86mm × 71.7mm
Compression ratio 10:1
Max power 147kW @ 6000rpm
Max torque 255Nm @ 4000rpm
Fuel Tank Capacity 65 litres
Fuel type Unleaded premium gasoline
Fuel Consumption 9.1 l/100km
Transmission 5 speed manual or 4 speed automatic
Drive Layout FR
Steering Type Power assisted rack & pinion
Front Suspension Independent suspension multiple link system
Rear suspension Independent suspension multiple link system
Front tyres 225/45ZR17
Rear tyres 225/45ZR17
Turning circle 10.2 m
Coupe Sedan
Exterior Length 4580mm Exterior Length 4705mm
Exterior Width 1725mm Exterior Width 1720mm
Exterior Height 1340mm Exterior Height 1375mm
Wheelbase 2665mm Wheelbase 2665mm
Front Track 1480mm Front Track 1480mm
Rear Track 1470mm Rear Track 1470mm
Ground Clearance 140mm Ground Clearance 140mm
Weight 1340kg Weight 1370kg
Standard features Rear spoiler, Driver airbag, Front passenger airbag, Anti-lock braking system, Front seat belt pre-tensioners, Front seat belt force limiters, Rear seat lap sash belt, Child seat attachment, Side impact protection bars, Power windows, Central door locking, Steering wheel height adjust, Leather steering wheel, Ultraviolet reducing glass
Optional features Front fog lamps, Rear fog lamps, Xenon headlights, Front spoiler, Rear window wiper, Side airbags, Navigation system, Alloy wheels
Edited by r33cruiser
try the ECR34
Make Nissan
Model Skyline
Model Variant 25GT
Year 2000 to 2002
Seating Capacity 5
Drive Layout FR
Coupe Sedan
Thanks man! your a legend!
I've looked around and seen hardly any 2door R34's do they make 2doors of this model?
This changes my plans now heh, i might get one of these instead of the R33GTS
but we'll see
here ya go mate this is the cheapest i could find.
http://www.carsales.com.au/used-cars/priva...amp;Make=NISSAN
$14,500....2000 model
Very nice, thanks a lot man!
I'd be looking at turbocharging it after a while (hence the other post) Any idea how much it would set me back for a mid-level turbine kit and installation? I've noticed there's not a whole lot of space in the engine bay.
just off the top of my head. a gtrs= $2000ish
manifold= 400-1000
dump pipe= 300+
ecu, injectors electrics= 1000-3000
not to mention forged pistons and rods=4000ish, or u could go the det items=1000max
you could do most of it yourself but if u want it installed looking at around 2000.
ofcourse prices will vary. i highly suggest this link it has everything u need:
http://www.skylinesaustralia.com/forums/tu...N-A-t33407.html
got a gt25 myself. 1998 model.
great car man, you can have lots of fun with it.
unless you have license restrictions, get the gtt.
and yep turbo'ing your n/a isnt too hard. there are forums on here that will show you what you need=].
Thats good to know, thanks for your help guys! All i need to do now is to pick which one to get haha.
IF you need to go the n/a route, I'd suggest looking for a GT-X(?)
It's meant to have the turbo version goodies, like bigger brakes etc, just n/a
then when you do eventually turbo it it will be like a GT-t
P.S don't ask me any details on the car I just mentioned coz I only know about it from what I've read on this forum
lol good one yoyo.
yea mate. get used to the handling, push it to its limits. then when u are off your p's or wateva. u will know how to control the turbo'd version much better, and will be more confident because u know the limits.
only thing u have to worry about is the power when u upgrade. but keep in mind 140rwhp on a r34 na is nothing special, so when u upgrade it will be 'scary', lol enjoy it.
lol good one yoyo.
Hahah yeah! not a bad idea, i'll figure something out, cheers for the help mate!
    • I'm keen for this content to 😂
    • Hi All, I'm based in Sydney and want to get hold of 4 stock R34 GTT wheel caps as pictured. Cheers
    • Haha im flattered! Although my poor boat is collecting dust in the garage, as it hasn’t been driven in like 6 months. I forgot the to put the trickle charger on too, so the battery is likely toast now.. I have the frenchys kit. It is fantastic. My only gripe was that the hard lines from the firewall needed some tweaking, however, this was mainly due to my specific turbo and dump combo. The weight and size packaging is much nicer too. I think I have some pics on my build thread somewhere.. my justification for the kit was more “why not” I had gone to the trouble to modernise just about every other part of the car..
    • Actually, ethanol has probably never been cheaper, on a tax free basis, than petrol. With fuel excise being what it is, and only being levied on the hydocarbon component, not the ethanol component, and ethanol for non-drinking purposes not being subject to liquor excise - E85 was cheaper, but not because the combustible liquid itself was particularly cheaper.
    • Maybe? If changing the cat to a higher flowing cat, caused the turbo to spool more quickly, and those areas of the map had not been tuned for the boost level it is now seeing, then yes you would need a re-tune. How dangerous it is running without the updated tune would depend on how far out the tune is with the now higher boost levels, how the engine protection has been setup, is the ECU compensating with a wideband sensor, is the boost control closed loop blah blah million other things... But yeah having said that, I wouldn't be surprised if changing out the cat for a high flow, in say a full 3" exhaust, made no noticeable difference at all.
