try the ECR34
or failing that a R34 25GT
Vehicle Specifications
Nissan Skyline R34 25GT
Make Nissan
Model Skyline
Model Variant 25GT
Year 2000 to 2002
Body Type Coupe and Sedan
Seating Capacity 5
Engine Code RB25DE Neo
Engine Type Water cooled Inline 6 cylinder DOHC 24 valve
Engine Size 2.5 litres (2498 cc)
Bore × stroke 86mm × 71.7mm
Compression ratio 10:1
Max power 147kW @ 6000rpm
Max torque 255Nm @ 4000rpm
Fuel Tank Capacity 65 litres
Fuel type Unleaded premium gasoline
Fuel Consumption 9.1 l/100km
Transmission 5 speed manual or 4 speed automatic
Drive Layout FR
Steering Type Power assisted rack & pinion
Front Suspension Independent suspension multiple link system
Rear suspension Independent suspension multiple link system
Front tyres 225/45ZR17
Rear tyres 225/45ZR17
Turning circle 10.2 m
Coupe Sedan
Exterior Length 4580mm Exterior Length 4705mm
Exterior Width 1725mm Exterior Width 1720mm
Exterior Height 1340mm Exterior Height 1375mm
Wheelbase 2665mm Wheelbase 2665mm
Front Track 1480mm Front Track 1480mm
Rear Track 1470mm Rear Track 1470mm
Ground Clearance 140mm Ground Clearance 140mm
Weight 1340kg Weight 1370kg
Standard features Rear spoiler, Driver airbag, Front passenger airbag, Anti-lock braking system, Front seat belt pre-tensioners, Front seat belt force limiters, Rear seat lap sash belt, Child seat attachment, Side impact protection bars, Power windows, Central door locking, Steering wheel height adjust, Leather steering wheel, Ultraviolet reducing glass
Optional features Front fog lamps, Rear fog lamps, Xenon headlights, Front spoiler, Rear window wiper, Side airbags, Navigation system, Alloy wheels
Edited by r33cruiser
try the ECR34
Make Nissan
Model Skyline
Model Variant 25GT
Year 2000 to 2002
Seating Capacity 5
Drive Layout FR
Coupe Sedan
Thanks man! your a legend!
I've looked around and seen hardly any 2door R34's do they make 2doors of this model?
This changes my plans now heh, i might get one of these instead of the R33GTS
but we'll see
here ya go mate this is the cheapest i could find.
http://www.carsales.com.au/used-cars/priva...amp;Make=NISSAN
$14,500....2000 model
Very nice, thanks a lot man!
I'd be looking at turbocharging it after a while (hence the other post) Any idea how much it would set me back for a mid-level turbine kit and installation? I've noticed there's not a whole lot of space in the engine bay.
just off the top of my head. a gtrs= $2000ish
manifold= 400-1000
dump pipe= 300+
ecu, injectors electrics= 1000-3000
not to mention forged pistons and rods=4000ish, or u could go the det items=1000max
you could do most of it yourself but if u want it installed looking at around 2000.
ofcourse prices will vary. i highly suggest this link it has everything u need:
http://www.skylinesaustralia.com/forums/tu...N-A-t33407.html
got a gt25 myself. 1998 model.
great car man, you can have lots of fun with it.
unless you have license restrictions, get the gtt.
and yep turbo'ing your n/a isnt too hard. there are forums on here that will show you what you need=].
Thats good to know, thanks for your help guys! All i need to do now is to pick which one to get haha.
IF you need to go the n/a route, I'd suggest looking for a GT-X(?)
It's meant to have the turbo version goodies, like bigger brakes etc, just n/a
then when you do eventually turbo it it will be like a GT-t
P.S don't ask me any details on the car I just mentioned coz I only know about it from what I've read on this forum
lol good one yoyo.
yea mate. get used to the handling, push it to its limits. then when u are off your p's or wateva. u will know how to control the turbo'd version much better, and will be more confident because u know the limits.
only thing u have to worry about is the power when u upgrade. but keep in mind 140rwhp on a r34 na is nothing special, so when u upgrade it will be 'scary', lol enjoy it.
lol good one yoyo.
Hahah yeah! not a bad idea, i'll figure something out, cheers for the help mate!
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
