What Tyres Should I Run To Obtain Better 1/4 Times, Also Tyre Best Pressure?....help! :)
Hi guys,
I'll be running my car down the 1/4 in the next two weeks, its a r34 gt-t making about 200kw auto, now i have the choice of either running my works meister 18x10's on the rears which i wont be doing due to the fact i dont have $34923923 for another set of 18inch tyres :)
Now i can either run my standard r34 gt-t rims on the rear with summitomo 90% tread 235/40/r17's on the rear or i have a set of r33 rims which i can put some 16inch rubber on of my choise.
Now to obtain the best result down the quarter, what rims/tyres cobination would optimise my time, and also what is the best tyre pressure to put the tyres to?
Anyone with past experience your help is needed.
Thanks guys! :)
Personaly I have always been a fan of racing a car exactly as you drive it every day.
I do agree with you there, although i always get a bit tempted on the burnout pad before i run :D , so personally just dont want to ruin my perfectly good 18 inch tyres, would perfer to use my 17s or buy some decent rubber for the 16's, just need to know what combo/psi would be best.
Thanks :laugh:
do some googling ....
there is a formula to work out how to get maximum traction/responce from what size rims you run & tyres. with diff gears etc etc...
basically i was sort of explained to by a mate who worked it all out for his datto with a ca18 in it... that as a really rough guide you should be approximatly crossing the line at the top of your 1:1 gear. ie. 4th.
for me in my s15 its the top of 5th... but just realised yours is an auto...
so if you want more responce drop down to a 16" tyre with about 55 profile on it and loose some pressure out of it. should work great.
This is exactly what is needed and nothing more:
http://www.skylinesaustralia.com/forums/Mi...es-t204639.html
They would be great! but dont want to spend that much.
I've decided to run the 16's although still dont know what PSI to run them on, and also what profile tires to get. would 225/50/ZR16 be about right anyone suggest anything better? PLUS PSI, PSI,PSI common guys someone has to know whats best to run the tires on i always see people dropping tyre pressure. ;) It's not that much of a secret is it :banana: lol thanks guys.
If you have to buy tyres for your 16" rims than for an extra $100 you could get the above mentioned.
I can get good 2nd hand tires with reasonable tread for under $100 so $500 is a bit to steep. Thanks anyway mate.
Just need to know the best profile and psi to run :D
225/50/16 @ 28psi
Remember they are road tyres not drag radials so lowering the pressure won't have much/any effect on performance like a drag slick or radial would.
    • We will review wtf is going on, but if you made any donations let me know and i will follow it up with the admins
    • See, that button sounds like perfection Duncan! My eyes really don't like light shining at them from a dash when I'm driving. Being part red colourblind, I've found for most cars that I can change colours on, I set everything to red, so my eyes see the elast amount of colour! I miss normal gauges in cars
    • bro, knowing the Japanese in  the 90's, i wouldn't be surprised if they shared components across their model lineup.
    • Maaaan so many "little" things  i rly hope my old RB20 would be "ok" and not too bad. I try to learn what and what not do i need. I look at crossmember at it looks different...even parts numbers are different. Wiring and all that i rly do not know...yeah someone mentioned the speedo thing. On that yoke clip. I rly do not know what can and cant be done "custom" so that is why iam asking to know and not be suprised 🙂  I know what it looks like
    • Oh, there's also the gearbox crossmember which will probably be different between the small box and the big box, and the wiring loom will probably need to be modified, because the plugs for the switches etc, will probably be different. And I think the speedo on the small box R34s is from somwhere stupid, like the diff, possibly, so you'd need to work out what needs to be done about that (assuming it is different). I think the thing you need to realise is that the front end of that yoke is a large hollow tube with splines on the inside that mates with the splines on the box's output shaft. It is a dedicated thing - not available "aftermarket". They were made to suit that box, by the car's OEM.
