Great day, was great to see all the members come down, hopefully everyone enjoyed the day. Thanks to Kaz, Mav, Bec, Ash on the BBQ and the rest of the SAU crew for their time.
Ray's X5 made 139kw.. what a BANGA! :D
Here's a few pics.
  • Replies 286
great turnout - thanks to all of those who helped organise the day and set it up
good meet some of the new members too, i was the guy with ash on the bbq (im in the orange autosalon shirt)
lots of good cars and a wide ranges of results. even some mid 300kw cars which is good
if anyone has any questions on what the info on their dyno sheet means or what the curves actually tell you post up and we can provide advice/help
and recommend changes to make the car perform better, etc etc.
Hi guys! Anyone that joined up yesterday, please don't all send me 50 PMs, your access to the members only section will come into effect in the next few days and anyone still needing stickers should get them around Wed, so let me know if there's any outstanding issues at the end of the week :D
Thanks guys,
Cheers!!
~Kaz
202kw's for me. Not bad but there are plenty of guys making more than that.
Thanks to the organisers. I had fun except the defect on the way down there.
Who won the 'guess the kw' comp?
ah nice
i got 204.8
need to get my boost controller in and a bigger fuel pump and z32
then shell make some good numbers :P
Yup, the oldest skyline at the day held its own against its larger capacity brothers and all with a stock turbo. :D
Another RB20 came very close that had a 2535, nice curve as well.
Then there was a white 32 with an RB20.......that began its ramp up with af/r's starting at 17:1 and dissapearing off the top of the chart. Operator backed right off and I assume he thought something was amiss as they redid the sniffer and started again to get the same result.
Engine was obviously a time bomb but owner is lucky he spent the couple dollars to put it on as it has saved him an engine.....if its not already too late.
yeh it was 2 cars before me
made like 80rwkw cause they had to back off
Get a K&N panel filter, should allow it to breath easier.
Does you dump pipes and cat look like this?
<image links removed but appreciated :D>
Standard dump pipes will look like straws compared to these. LOL!
They are probably aftermarket because they're big and thick (with surface rust :D ).
I measured it recently and I couldn't seem to get an accurate measurement before the cat but its a thick pipe, somewhere between 9 and 10inches circumference so about 3inch thick near the cat...(hard to measure). The exhaust itself appears to be roughly 3.3inches near the end so its probably a 3inch pipe.
The compliance cat is about 8.5 inches round or so, it worked out to roughly 2.5inches entry and its very thin and flat, looks like it won't be flowing much air.
I would take a photo but I'd need to jack up the car and its going for tuning in a week or two so I'll know for sure then.
New cat and highflow panel filter, tuned boost controller and PowerFC (replacing the mines ECU) should make a huge difference over the previous 156.6 awkw :P
Really? Thats nice to know :D
How do the AFR's look? Look all over the place to me lol
afr's look typical for stock ecu, they like richen up the higher the revs go. Mine used to plumet to near 10 whereas yours are hovering around 11 in top end. more power could be easily made leaning them out a bit more to 12:1, but ofcourse you need to find yourself an ecu... my car runs a flat 12:1 afrs with power fc and makes 202rwkw stock turbo, this was at RE also. I used to get some flat spots the rev range with my stock ecu under increased boost after the exhaust and fmic.
who won lowest power?? by the time i left i was still winning :) (or, losing?)
also, i paid for my renewal but forgot to get the expiry date updated, can i just change it on the card?
ill send you one this week..
same with everyone else that didnt have their card handy.. :)
here's my graph, feel free to analyse it:
just remember it's an NA 300ZX, not a twin turbo. I did a compression test last week, 190psi on all 6 cylinders and I've got an Apexi pod, 2.5 frontpipes, metal cats and cat back and also a lighter tailshaft. stock NA Zed with perfect compression should hit 120rwkw. I think I may have hit the Jap speed limiter though.
abit dissapointed that I only got 1 run... started missfiring and Ray backed off (he's got good ears.. I didn't hear anything until it returned to idle.. sounded like a rexy). Was only the coil pack connectors coming loose so I dropped a cylinder... just pushed them back on but there was no point asking for another run as they'd just come off again. my fault for being lazy, I have the new connectors in my room but didn't install them because my coilpack connectors have never come off under normal load on the street. Also need to sort out some vacuum leaks and replace O2 sensors.
I want to go back for another run after I fix everything. Hoping for 125-130rwkw using the stock tune. I think there's definately more in it and maybe next year I'll get extractors and a retune and try and hit 150kw.
Other than that it was good to meet a few people even though i didn't stay for long, won't feel like such a newb next time I'm at a SAUVIC event. Thanks to all the people who organised it.
Oh hey Jordan!
Ya bro happy with the dyno chart? If not free up that exhaust and let it flow better.
yeah i reckon an exhaust is definitely on the agenda
want to do a few small things first
fix the seat, gear boot, gear nob, tint etc
then a few mods
im still not 100% sure if i just keep it stock or not
maybe just get an exhaust and keep the stock one in the garage, so i can always put stock back on for a fully stock re-sale
i reckon you would fetch more for a stock 32 in a few years than a molested one :D
Oh hey Jordan!
Yeh i think it was a reasonable result and he was pleased to see that it was all in order - was fresh off the boast only a couple of months back. exhaust is probably on the cards sooner or later especially after he noticed my gtst pulls away from him... :D yet his 'R' pulls hard for 100% stocko :laugh:
Guest
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
