  • Replies 286
no, i've driven GTRHKS. The guy that took it to the dyno day just bought it that week. My mate used to own it, but swapped that and his blue S15 for an R34 GTR.
I mean no big deal really there are lots of quick gtr's, but it was my first time ever driving something over 200rwk. Yes, i was sweating :laugh:
Edited by 180_mph
Had to take the poor 300C to the Chrysler doctor today
It was revving and driving weirdly on the way home
They found a bar code label stuck around the throttle butterfly
Didn't dare say anything about a DYNO day!
Checked revs to road speed also 2000revs = 90kph
red line 6500 to 7000 = between 290 to 315kph in 4th gear still got 5th to go
(bugger the wind resistance)
i think my POS n/a won the lowest power out of the lines :D lol, something majorly wrong with my 3rd gear. should of been making about 110-115kw's
Not fussed tho just going forced induction soon hehe :/
Edited by 4Door_33GTS
r33 gtst's dead stock make 120kw~ atw, you sure your N/A would be pulling 115kw atw?
they're more around 140rwkw...
is it? i remember someone with a stock r33 got lower, meh could be wrong :D
edit: im finding some values of 130kw, so if we throw in an auto transmission it could drop to 120~kw :/
that sounds like a reasonable coverup? :D
So whats the deal with the raffles? I remember last year there were raffle prizes :(
pffft. highflow panel and constant 7psi (stock boost)
First run i got 101 kw's, then 84 :/ ray said it was the more accurate one or something so thats the one that was printed, is it me or is my graph really retarded? lol must be the auto.. i know for a fact that my 3rd is playing up cos i can physically feel it when i drive and look at the revs drop :D
anyways can anyone make sense of this? lol
Edit: my AFR looks much higher then others too..?
~ RESULTS ~
OK - winners are........
Most power (AWD) - Alex Cheung (Jockey) - silver R33GTR - 454.9 awkw
Most power (RWD) - Matt Karlsen (GTTR34) - black R34GTT - 353.7 rwkw
Lowest Power - Scott Bailey's (SABBAI) super wagon (Mazda) - 48.9 rwkw
Lucky Dyno Draw - Mark Pether (Mutex)
Guess the KW's Competition - Rob Nigro (THENIG) with a guess of 138, Ray's X5 ended up making 139.6
Thanks to our great friends at Unique Cars, all of you have won a Meguiar's Car Care Pack valued at $49.95. Contact me by PM or email - [email protected] to arrange collection of your prize.
Other results are attached.
Thanks to everyone for coming - was a great day.
Dyno_Day_List_080301.pdf
Guest
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
