  • Replies 286
I'm keen as mustard form this.
I've just spent the last 2 days polishing and detailing my car, and she looks better than she ever has before.
Wow... ...Shiny...
I always have people tell me how clean my car looks... ...but at the moment she's a dirty as a hooker on a monday morning...
I was hoping I would get my car back today for the dyno day, but looks like the workshop is screwing me around..
I got told that I'd get a call but no go! Went in and the guy wasn't there.
Hopefully there is one on again soon.. Was hoping to meet some people from SAU! -_-"
nah another blue s13 rocked up right after you left... i forgot what it made... but ya it was 1kw more than yours
sorry :)
hahaha :P so what did your car make then? ;)
what was the most powerful rb20?
202kw's for me. Not bad but there are plenty of guys making more than that.
Thanks to the organisers. I had fun except the defect on the way down there.
Who won the 'guess the kw' comp?
the r31 got 233 rwkw's
Yup, the oldest skyline at the day held its own against its larger capacity brothers and all with a stock turbo. :down:
Another RB20 came very close that had a 2535, nice curve as well.
Then there was a white 32 with an RB20.......that began its ramp up with af/r's starting at 17:1 and dissapearing off the top of the chart. Operator backed right off and I assume he thought something was amiss as they redid the sniffer and started again to get the same result.
Engine was obviously a time bomb but owner is lucky he spent the couple dollars to put it on as it has saved him an engine.....if its not already too late.
Edited by FATGTS-R
That was my R32 with the 2535...made 223.4rwkw...turns out my boost gauge was inaccurate and it was only running 17psi...should have been 19-20psi...but i'm happy with the result regardless...in the end...it was a great day...cheers all...
Oh...and go the rb20!! :)
Edited by limpus
What a great turn out!
Some spectacular cars out there today! Good to meet some of the memebers on here in person. Would have like to see the Millenium Jade coloured R34 GTR V-Spec II Nur run a dyno.
Did Snowman run? If so what was his power output?
The Blk R34 GTT with the GTR kit and blk wheels was sick! I followed you for abit down Springvale Rd.
So many cars too may to mention. GREAT DAY!
PS took afew pics.
Guest
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
