Hey all,
Went to calder last friday for the 1st time and and ran my car a few times, was wondering what sort of times other similiar cars was getting as i was going up against 11 sec cars!
My car and Mods:
1993 R33 Gts-t (Auto)
Performance mods:
Apexi N1 catback Exhuast
R34 Side mount cooler
running 9 Psi
Tyres: 17 inch rims with 245 continental tyres (about 60% thread) 22 PSI
and everything else is pretty much stock. Not tuned or anything like that.
My best time was:
14.29 @ 157 km/h
most my times was between 14.3 and 14.6 - i had about 11 runs.
I found that the car would launch hard but then die in the last 100 meters :D
i would be very happy with that time.
our skylines up north just cant seem to push the same times. different track and maybe the prep will probably be part of the reason.
what 60ft time?
hmmm really? the weather could also play a part i guess....on friday (when i went) it wasnt too bad, track temp was about 24 degrees..
60ft time was: 2.11
660' - 9.12 @ 125 km/h
That's a good time.
Are you planning to go quicker?
ye id love to break into the 13 seconds... and then i will be happy.
My car is a daily driver, ive had it for about 5 years and i've done 110,000 km's on it since ive got it...
I rekon maybe with a FMIC, high flow cat + dump pipe i could improve the top end a bit and maybe break into the high 13's!
But at the same time, as it is now, its great for day to day street driving / over taking and quicker off the line than more modified / tuned manual R33's of some of my mates and i don't know if i want to lose that to gain a few milliseconds on the drag strip!
What was your 60ft times?
Their is some easy time to be made up at a reasonable cost.
1) Get yourself a pair of R32 GTR rims (or 300ZX rims) and buy a new pair of Mickey Thompson ET Street tyres. This will lower your 60ft time without a doubt and should cost under $700.
2) Get a 1 piece front/dump pipe along with a new hiflow cat to finish off your exhaust system. You will have more power right through the rev range which will result in a higher terminal speed (currently ~94mph) and should cost under $700 as well.
60ft time was 2.11
thanks for the tip! ye i'm def going to invest in making the exhaust to turbo back me thinks!
Justjap have a nice deal going for you:
http://www.skylinesaustralia.com/forums/JJ...RB-t204414.html
So much cheaper than I first thought, wouldn't take more than an hours labour if it is a straight fit to your existing cat-back exhaust so you should be able to have it fitted for about $500 all up.
is it losing traction on launch?
being auto and stockish, I don't think it would.
anyway.
to get something like a 13.9 (in to the 13's as you're said).. get the exhaust finished (dump pipe and front pipe in one and a new large cat).
then get an SAFC and have it tuned.
Even the blue screen SAFC would get you a good increase in power, especially in the upper end.
the Blue screen ones would be below $300 now for sure.
dump/front pipe in one can be picked up for about $200 from a number of places brand new.
SAFC tune will probably set you back about $200.
all of that easily under $1K.
should push power to near 190rwkw.
should net you 13.xx
if you are losing traction on launch, then look in to tyres too.
I would also race with 16's instead of 17's.
I dare say that your 17's with tyres would weigh more than the stockers which weigh 16kg with tyres.
EDIT - don't replace the R34 SMIC with a FMIC.
you will lose the response that you love at the moment.
it is more than up to the task.
If the R34 SMIC doesn't have any ducting to it, I would look in to making one for it.
Water spray is another option but probably not needed.
Edited by GTST
his current mph is more like 97
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
