The Tool...i agree totally!! :uh-huh:
the drive between Syd and Canberra (for example) is SOOO mindnumbingly boring sitting on 110km/h...and it's such a straight, safe road! Roads like that should definately have a higher limit. The only thing that keeps me awake is glancing at my speedo every 5 secs to make sure I'm not speeding too much lol
as for 50km/h zones...yeah we have them here, but it's "unless posted otherwise"...and most main suburban streets seem to be posted 60 (from what I've seen anyway)!
some places where it's 50 (for example i live in a Circuit and it would be 50) you wouldn't be able to hit 60 if you tried, probably wouldn't even get up to 50 either!
Guys,
The blanket 50km/h limit has nothing to do with revenue raising. In reality it will have little or no effect on the motoring public but it will free up funds that are currently being spent on 50 speed limit signposting in residential areas.
When this comes into effect all collector and arterial roads will remain at the same speed limit and will be signposted accordingly, while residential and local roads will be 50. This means that the millions of 50 limit signs on local roads will no longer be required and the only speed limit signposting will be on major arterial routes.
On the subject of seat position I was unfortunate enough to attend a fatal accident where the driver had his seat back and "submarined" under the seat belt and drilled himself (I think it was a him) into the firewall under the steering wheel. I wouldn't wish that on anyone.
Geez I'm a little ray of sunshine today, aren't I?
Avagoodweekend,
Ben
i totally disagree! how can you say it isn't revenue raising...
all the cops will do is sit in unmarked zones, catching everyone driving along at the mind numbing speed of 60km/h and book em for 10 over..
how can you say that has no effect on the motoring public? looks to be a big effect to me! what next, 40km zones in suburban areas, followed by 40km zones everywhere... followed by walking because it will be faster!
    • Yes, but it's not as easy as pulling a fuse on anything other than an R32. There's a routine you have to do, involving disconnecting a loom plug and bleeding down the preload.
    • A question for tuning awd, is it possible to disable the AWD? The stagea is an EA/T AWD, Toshi had said on a GTR, he was able to disable it and make it 2wd. Just wanted to double check if this was possible
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
