Hey,
Bought a r32 airbox from a sau trader, didnt fit at all so sent it back to SAU Trader for a refund. He said that he will send a r33 airbox, i sent him a PM telling him it wont fit in my r32. After 3 weeks of sending him emails/PM's with no response, out of the blue i have a r33 airbox arrive to my place.....
so much for the credibility of SAU traders....
Just want this to be over and done with, anyone willing to purchase it off me? just want my money back..
Item: R33 cold air Air-Box
Location: Victoria, Ferntree Gully (would prefer pick up or meet somewhere)
Age: Received Today
Condition: Black fibreglass mould
Price: $100firm
Pics:
Thanks all
Patrick
https://www.sau.com.au/forums/topic/204472-fs-r33-podfilter-airbox/
Any other parts required to fit it that you know of? Does it just fit straight in to any R33 gtst? Anyone know?
Im assuming this will obviously work better than the standard airbox. Is it designed to house a pod filter? Or is it a complete unit.
its to house a pod filter, you will have to cut a hole on the left to pass the pod filter through. The box is mounted between the pod and the AFM.
It should pretty much fit straight on as it was designed for it.
If you live around Knox, i can happily meet up and show/explain it to ya :P
Yeah, may catch up with you, ill pm you if I get a chance, have a pretty hectic schedule. Dont put it aside for me though, im still not sure if ill take it.
With this though, you have legally have a pod and a front mount as the pod is housed, correct?
  • 2 months later...
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
    • No idea about Neil's steering wheel, but I have the same behaviour in the Stagea. I doubt it has ever been messed with so might be normal. Indicating to turn right at a roundabout and correcting even a little bit to the left to go around will cancel the indicator. Never considered it an issue other than it being a bit odd.
