  • Replies 109
well, Going by your mod list in your sig, Id wind 14 psi into it and Remap the ECU.
Then you start getting into aftermarket turbo/injectors/afm's, also GBox problems.
What Braking/suspension setup are you running?
And yes. This will ALWAYS happen./
Edited by R31 drift pig
14psi Shouldnt let go on a 20. And will be enough to keep you amused for a while. :D
As said, once you want more than that, starts costing a lot more cash.
Stock brake setup will be fine with good pads/fluid.
Running almost Identical setup, but with SARD fuel reg to jack a bit more fuel in.
itll always happen untill u crash, lose ur license or feel how 300kz feels like or buy a motor bike if ur power hungry ahahha
hehehe i lost my liscence then bought a gtr :D the boost bug has very powerful toxins... once your bitten you will just keep modding!! then take it to the track for all ur fun!!!
good luck joleo by the sounds of it yes you will feel like this for a long time!! maybe it will stop once your over the hill maybe not
gl
yeh its the wastegate action atm, i have a greddy B spec II electronic boost controller (that was a mouthful just to type lol) on layby so in the next few weeks i should have it :D
they should have a waring sticker on skylines...
*WARNING - You will always be power hungry if you buy this car!*
LOL... it's so true. Im already planning my next round of mods once I get the whore painted and driving for a while. (HKS 2535, External Gate, RB25 Box, Twin plate etc.)
Get a Walbro (GENUINE) pump, SARD fuel reg, Wind 14 PSI into it and remap to suit.
Exact setup I have in my car. Have Boostworx Daughterboard in the ECU, just need to tune it. (Once again, waiting to paint).
What's she making on 10psi? Mines making 180 odd on 8psi (Boostworx dyno) Shaun said to expect to see it crack 200 on 14.5psi.
Sounds like you already have a decent enough setup!
I must be odd, I have fairly minor mods and thats enough for me. Instead of wanting more power, I want another skyline! :) infact one of the skyline models im considering to get has less power then my current skyline :D
lol... Im not chasing more power now, Prolly gonna drive the car for 6-12 months and get used to / Refine the setup (Car hasnt been drifted yet) then Ill be upping the power to around 250 - 260 KW's at the wheels.
RB25 box/twin plate/single piece tailshaft will be simply for reliability.
And yes, it's gonna cost me a mint. :banana::down:
hey fellas wat power should i be able to get with this mods i got
full 3" exaust
front mont intercooler
lsd
exedy 3 puk clutch
greedy pro spec 2 boost controller
hks fuel cut defender
the last 3 items r on they way and should be here this week just wondering how much boost i could run with my factory turbo and the power figures i might get
yea illl get all that wen i get a bit more cash just hard to get cars tuned in alice theres only one dyno but the bloke that runs it has blown 8 cars up cause he dont no wat his doing his a motorbike machanic so got to send car away for tuning
Edited by fab34
ah k. You will need a FCD tuned through, need to set the 'cut' at the right point.
Boostworx remaps are only $550 inc. labour, and Im sure a majority of the SA people use Shaun to tune, and can vouch for how good he is.
And you get all those roads from NT to SA... :banana::down:
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
