Item:Custom built Jim Berry racing clutch
Age:3 months
Condition:Excellent condition
Price:$ 500.00
To Fit: R33 pull clutch
Contact: Warren
Comments: Near new Jim Berry Racing clutch from R33 GTR. Pull type clutch including near new flywheel, button clutch plate and 5,500lbs pressure plate. This clutch is in excellent condition and was installed in my car for only 3 months, while I was waiting for a Nismo from Japan.
Edited by wb1980
https://www.sau.com.au/forums/topic/204490-gtr-clutch-for-sale/
gday,
whats this like on the foot? is this a big single?
thanks.
Yeah its a big single, but has quite a long throw. Will be similar weight to most of the good singles. I still managed to drive it easily in traffic after getting used to it. Check out the threads regarding these clutches.
  • 3 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
