Rb20 Looms, Rb25 Cam, Tyres, Chip, Cradle Bushes, Ignitor, Std Inlet Manifold, Throttle Body, Hub Mounts
Cleaning out the garage and found a few parts no longer required
Rear cradle bushes, whiteline set of 6 suit most nissans, used for a few months only before replaced with alloy ones, new $120 sell $40
Rb20 throttle body with TPS, $30
Rb25 starter loom, $15
R32 GTR rear hub mounts, alloy, exc condition, $40
RB20DET ignitor pack, $25
RB25DET inlet camshaft, R33 model, excelent condition $50
RB20DET inlet manifold- bottom half - perfect for a custom fab plenum on to be built on $30
2 x Dunlop 225/50/6 SPsport 9000 tyres, new new min 7mm tread, cost around $300 each new, $100 each
Dr Drift tuned chip to suit rb20 with 550 cc injectors, z32 afm and to4 size turbo, ran ok on my setup but this will change for each individual car, $20
All parts in good working order when removed, in Adelaide but will ship at buyers expense
Edited by Clint32
sorry i cant answer that for sure, do a search on here and you should find an answer
will the igniter work on a series 1 r33 rb25det if so sold to me
can you please tell me how much including frieght to postcode: 2228 in Sydney
i will take it
I have someone elso who wonts to buy the loom with that plug attached, so at this stage im waiting to hear back from him, failing that i would only sell the loom complete
hey iam after the o2 sensor but i need both ends off the plug awell if thats ok
    • Ah yeah I forget we aren't talking about an RB.
    • Fellow ADHDer to fellow ADHDer; Don't chase that paint perfection. Paint the bumpers, and put them on.  Leave the respray for another day. Plus, no one is going to see those old areas above. Any spots of surface rust, give them a clean up, prime, then hit with a white paint just to protect them from rusting. Again, no one can see it.   #Mine hasn't been on the road since 2011 cause ADHD... I've slowly learned not to keep f**king with shit if I don't need to...
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
