Ok people,
I have found a point of contact in the US who can ship parts to OZ within a week and for very cheap.
Speak to Jason and tell him i recommoneded you "Yianni"
He is a good guy, any part you want he can get. Just email him the part number you want and he will send you a paypal invoice to pay which happens instantly.
Here is his email: [email protected]
Thay are a company located in California they also have a website http://www.riversideinfiniti.com
Cheers
https://www.sau.com.au/forums/topic/204527-you-want-parts-cheap-and-quick/
This is the first paragraph from teh email i recieved when i sent an email to Jason's email address that i have previously used to source my parts:
Tony Nazzal <[email protected]>
Hello.
My name is Tony, I am taking over for Jason's online customers.
Jason will no longer be working with us unfortunately.
Its a shame as Jason was very good with costomer service as well as giving us great prices. Will see if Tony can live up to the high standard or it might be a bit of a blow for us all..
sincw you guys are buying from them - how are they translsating the car. they asked me for a USDM VIN when I rang them and this was the new parts guy as well.
if you have a 16 digit VIN can I grab it please. I want ot get a few bits for the OE cruise control that I'm researching. :)
actually if you're chasing disc rotors, see rs73 i bought RDA slotted rotors off him:
http://www.skylinesaustralia.com/forums/Ch...de-t184642.html
Thanks mate justed PMed him got a very good price ? WazR32Gtst did you get some disc rotors for your V35 ?
does this help, chris?
VIN: JNKCV54E43M212543
from a white 2003 G35 coupe
how did i get it you ask? thinking outside the box...!
also chris, i'll be around between 7 and 730 on thurs, is this ok?
thats what I needed. Iwas going to go digging on ebay for one though I wasn't sure if they showed up.
ta.
time is fine - I'll be here.
I spoke to Jason a few days ago, he isn't leaving.
Also you might not notice this but i did. The third brake light located on the parcel shelf sometimes dims and it is sometimes brighter. They are a common problem in the 03, 04 models. Anyway i took the light out, very simple all you have to do is push forward on the back of the housing then up and out. 2 screws to remove the bar of LED's.
Anyway i took the bar of 6 LED'S out and hooked it up to car. I noticed that one of the resistors wasn't welded onto the circuit board properly. Very easy guys you will see that something is loose when you tap it.
Just letting you know because that bar of LED's is around $150 shipped.
    • Well, in 2007 he must have been charging about $1800 an hour. He only looked at the car for 5 minutes. And another 4 to write the report wrong, and another minute to correct it. Mind you, this was for a car that was: Stock engine, fmic (hole in drivers guard), all alloy intake and custom air box, 3 inch turbo back exhaust, lowered, and a set of 17" Advans (255/40/17 rear and 235/45/17 front). It was nothing crazy. The blue slipper wanted the "hole in the guard" engineered. But that was because he got the shits that I wouldn't "relocate the battery from the boot, back to the factory position in the engine bay"... In an R33 GTST...     Also for emissions, E85, and don't go wild on timing. It's amazing how the closer you get ignition timing towards max torque, the last couple of degrees really throw NOx counts right up. And for the huge increase in emissions, it's only a small increase in torque.
    • He'll be looking down and swearing about "the damn apprentice" for trying to convince Duncan to use percussive maintenance... 😛
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
