You Want Parts Cheap And Quick?
Ok people,
I have found a point of contact in the US who can ship parts to OZ within a week and for very cheap.
Speak to Jason and tell him i recommoneded you "Yianni"
He is a good guy, any part you want he can get. Just email him the part number you want and he will send you a paypal invoice to pay which happens instantly.
Here is his email: [email protected]
Thay are a company located in California they also have a website http://www.riversideinfiniti.com
Cheers
This is the first paragraph from teh email i recieved when i sent an email to Jason's email address that i have previously used to source my parts:
Tony Nazzal <[email protected]>
Hello.
My name is Tony, I am taking over for Jason's online customers.
Jason will no longer be working with us unfortunately.
Its a shame as Jason was very good with costomer service as well as giving us great prices. Will see if Tony can live up to the high standard or it might be a bit of a blow for us all..
sincw you guys are buying from them - how are they translsating the car. they asked me for a USDM VIN when I rang them and this was the new parts guy as well.
if you have a 16 digit VIN can I grab it please. I want ot get a few bits for the OE cruise control that I'm researching. :)
does this help, chris?
VIN: JNKCV54E43M212543
from a white 2003 G35 coupe
how did i get it you ask? thinking outside the box...!
also chris, i'll be around between 7 and 730 on thurs, is this ok?
thats what I needed. Iwas going to go digging on ebay for one though I wasn't sure if they showed up.
ta.
time is fine - I'll be here.
I spoke to Jason a few days ago, he isn't leaving.
Also you might not notice this but i did. The third brake light located on the parcel shelf sometimes dims and it is sometimes brighter. They are a common problem in the 03, 04 models. Anyway i took the light out, very simple all you have to do is push forward on the back of the housing then up and out. 2 screws to remove the bar of LED's.
Anyway i took the bar of 6 LED'S out and hooked it up to car. I noticed that one of the resistors wasn't welded onto the circuit board properly. Very easy guys you will see that something is loose when you tap it.
Just letting you know because that bar of LED's is around $150 shipped.
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
