  • Replies 487
Posted Images
Thanks duncan...
which reminds me...
i maybe have a secret weapon up my sleeve if its in Aus by June...
How does this sound??
Hahah, so much for "secret," Paul...
Lemme guess, it's a built 240K with sponsorship from Krispy Kreme?
:domokun::);)
Thanks duncan...
which reminds me...
Hmm im liking your secret weapon!!! :thumbsup:
I might be able to recruit some other SAU skylines (not on the forum much)..try to get them involved as there cars are show quality..
Damn that'll beat my Nur Spec II :blush:
Very nice tho
I saw the Nur spec on monday night they were out for drives i reckon u should convince him to come and bring us PIZZA lol maby he could become a sponser ( just a thought ).
I would love to see an r35 on our display but thats a massive call to make i wouldnt have said it till u know u can get its attendence. I wanna see it on the dyno 2 lol
:nyaanyaa:
Yep meeting is a must and would like early March??
Yes, we really do need a meeting... it is a must... and its a must that its close to me as i have no licence....
Jess, we will chat on the weekend and see what we can decide... we can have a meeting at my work maybe??
That's fine with me, I'm easy :happy:
During the week is probably better for Jay...
Would we all like to have it in Westfield Miranda - NOT!!
I will speak to work tonight about it... Just need to know how many people to expect??
Table for 20??
Also, we may be able to use one of our function rooms
I doubt we will get 20 people there... I don't even think SAU NSW hit that at the AGM... still broke the record though :happy:
probably about 10 most likeyly...
And I'm fine with Miranda Westfields, I'll even come pick you up... But from there we'll take your car... it probably needs its legs stretched :P
Guest
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
