Hey guys, i really want to buy these tyres as i know theyre really good, just wondering if a 9.5" te37 +12 offset rim would fill out the tyres good?
Ive been told 265 on some tyres look thinner compared a 265 tyre of a different brand which would look more wide, fat and agressive (even though they are still 265's), What would the falkens be wide or thin?
My other option is the toyo t1r's
Edited by nsta
iv tried these tyers they were "cheapish" but not too bad, looks FAT ASS from the back on my works rims n had ok grip except the fact that i was runing 18s made it very crap to take off and at the qmiles was spining way too much on 1st and 2nd too...
IMHO put it on ur rims n put it on the car then see if u wana keep it or tell them u dont like it..
crisis situation, should i go s03's, or f452's, or re55's in really good condition for less than $600 for all four).....application is street use
s03s are 285's
f452's are 265's
and re55's are 265;s
will the re55's look like a wider tyre cause they are semi slicks?
OK lets be practical this is what i do for my GTR. i buy nasty nankangs because.
1. the price is cheaper when you add tyre+balance+wheel alignment = cheaper than the rest.
2. I have not fixed my negative chamber and all GTRs will have this unless you spent $$$ correcting it. This means 30K or 1yr driving is all your going to see before your tyres are unroadworthy.
3. I have a grid dancer installed in my car its a electronic device about $250-300 I highly recommend this upgrade because of the shit tyres i use the grid dancer shifts the torque to the front wheels between 20-50% and man driving in the rain is no problem the crap nankangs perform like Yokohama Advans in the dry :-)
4. therefore the money i save from buying expensive one pair for the year i can buy 2 pairs of crappy tyres for 2years.
tip hard compound tyres will last longer but shit in rain and when cornering hard.
This is what i find that works for me, maybe not for you.
As i said 265 will definitely fill the rim - I actually want 245 on mine cause I have a R32gtr and fitting the damn things without scrubbing under the guards is a pain the rims are actually under the guards but tyre is wider.
offset has nothing to do with what the size of tyre goes on a rim. its the rim width that restricts you. offset is to work out if its going to touch the brake caliper and how much its going to poke out from the guards or how much dish you are going to get. correct me if im wrong.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
