fark they even *look* expensive. but the adjustment on the end of the lca shown is perfect. I agree with your concern about the adjusters holding, they aren't an option in our class so I don't have any experience.
what we are now allowed to do is move suspension mounting points by up to 25mm, that is one option to widen track and give increased camber. bit fiddly though, and obviously the result is not adjustable.
Well it would be one of those circumstances where you aren't so much moving it outwards as returning it to where it used to be before the top arm was shortened.
In any case the bling LCA's on the previous page are a rather sobering $1000 for the pair.
Apparently Moonface Racing do an odd balljoint/LCA extender arrangement which also migrates the front roll centre. But I don't want to go down that road again. Wasted time/effort on it previously.
it's a bit hard to say as a lot depends on ride height too. you could always be conservative and just get the -5mm or even standard length arms, then adjust camber with some adjustable lower arms. not cheap but probably the best solution.
  • 1 month later...
Richard did you get the arms on yet?
Um :D Not so much.
Something in the gearbox/ATTESSA system has gone blah - probably a bearing, so I have it booked in to get it checked after Easter. Thought it best to let it feel some wrath (ok, neglect) in the interim.
don't know if this helps but
the part number for those nismo parts are
54501-RS585-R
54502-RS585-R
Price is 37,000yen (38,500yen with tax)
54501-RS585-R
54502-RS585-R
Yeah that is for the kit of three parts. Upper link bracket, transverse lower link & caster rod. Price is also PER SIDE.
omg i know that kit.
powerplay imports have one in stock and have had for at least 3 years. maybe see what they will part with it for
From Powerplay:
Thanks for your enquiry.
The Nismo Link Set prices is as follows:
Front Circuit Link Set RHS
54501-RS585-R $480 IN STOCK
Front Circuit Link Set LHS
54502-RS585-R $480 IN STOCK
From me:
Ow. Maybe if I named dropped? :)
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
