Hi all, i have a 99 rs4 prime ed, already have a cooler, pod, and elec boost cont., keen to spend around $2000 in the coming weeks on it, just asking ppl's opinion on what mods to do without going over my budget, any input would be nice.
Russ
https://www.sau.com.au/forums/topic/204659-best-value-upgrades/
got a turbo back exhaust? if so, this and a jaycar DFA(jump in the DIY sticky and look at the jaycar thread) http://www.skylinesaustralia.com/forums/Ba...html&hl=GCG
done suspension? spend the 2k on sydneykid's group buy
Brakes?
At least do the minimum of braided lines, new fluid and better pads.
If you wanna aim higher, some R32 GT-R or R33 GTSt brakes (which are the same) would be a good start. They're 4-spot on the front and 2-spot on the rear (standard Stagea is 2-spot front, 1-spot rear).
+11ty
for instant "yay I love my new mod" gratification, nothing beats a wicked set of upgraded brakes. Even just a change to braided line, slotted rotors and some new quality fluid and pads.
Seeing I have done mods in both the brake, engine, suspension and interior department, I will recommend the following in the following order.
Swaybars - $400
Castor bushes - $100
Bilstein shocks - $900 for all 4
Automatic shift kit - $450
Braided lines - $400 (If money permits :stupid:)
It really depends on the type of person you are though, if you like handling, straight line, comfort etc. I like handling
Swaybars - $400
Thats pretty much what l'm doing over the next month or so. There's a place in melb that does the shift kit for $400 installed (inc service on box).
Then just a FMIC and l'm done for a while.
Brakes l'll change when pads and disc's start wearing down. I don't drive hard so having slotteds & so forth isn't a priority atm.
power fc you will get better fuel economy and go faster.
genuis for an auto :banana: power FC is a good way to kill trannys, do a search
knox automatics? come for a ride if you want to see what it will be like before you buy, not gentle, but i like it.
MMMMM?
I'm just doing split dump and hi flo cat, 3". Also the little mod on the intake and a new O2 sensor and a Jaycar DFA.
Got my centre gauge holder for three. Moved the single Din unit to the bottom slot.
Have not gone for a pod, but have a Red Line panel with a cold air deflector.
At present i'm running a two stage (factory) boost control that I'm still working on. I want to devise a system that can use
both the factory settings with a preset MBC. A couple of valves and 12 volt actuators should do the trick. I know an EBC etc
can do the same, but I like the idea of lateral thinking??
At the next Qld meet I "hope" to have a lot of these ideas working, and hope to get some constructive input.
Suspension and brakes come next because I want engine management before I progress.
Greddy Emanage will work with the auto - set up and tune is about $1000 in Perth (not sure about elsewhere).
This will maximise the benefits you get from more boost and better exhaust as well as improving fuel efficiency. If nobody buys my car in the next 3 months then i will be fitting one to my car.
    • 2 spots that my exhaust guy joined the 2 pipes together  Made a big difference. I'm now able to live with it. I can make it louder if I want by removing the HKS caps.
    • Hi all, considering clutch upgrade to support 1130 engine hp from 1650cc injectors on e50 at 85% duty cycle (1650 x (11.85/14.7) x 85%). Narrows down to these three as they can be converted to use gm 26 spline input shaft if I ever want to use transmission with that input shaft (orc1000f and r3c easy/cheap just change center hub; tr2cd pricier must change clutch discs). Pricing orc1000f similar to tr2cd, r3c about usd 200 pricier. Orc1000f triple plate 200mm. Tr2cd twin plate 215mm. R3c triple plate 215mm. Claimed max torque : orc 1000f 723 lbs ft; tr2cd 800 lbs ft; r3c 1100 lbs ft. Why orc1000f triple plate but claims lower max torque vs tr2cd twins? Is orc1000f underrated? Any info maxing out these clutches? Info on street/traffic driveability/pedal feel? Thank you for any info on them.
    • Some troubleshooting, connect up a timing light/gun with a proper ignition lead on coil 1. Hold the revs at 4~4500rpm and see if your timing is all over the shop, scattering off its tits. If so, there's a high chance your CAS is fked. But I read you have a Link ECU ready to go in, why not just skip all this and put that in - will make troubleshooting so much easier.
    • Misfires when the car is fully warm are generally attributed to the coils (and/or the igniter, on cars with a separate igniter). They can stop working properly when they get hot for a number of reasons. Either electric/electronic, or from thermal expansion opening up gaps and allowing HV leakage. Seeing as you have replaced the coils, that could/should rule them out. But I wouldn't always assume so. Were the coils genuine? Or is there a chance you have bought some counterfeit Chinesium shit? Then we're back onto loom connections. They can fail when warm/hot for the same reasons. Inspections, cleaning of contact surfaces, ensuring that terminals are fully inserted, etc etc, are all justified. The same (heat effects) holds true for the other electrics and their connectors. AFM & CAS, primarily. If you try that Chinesium AFM, drive it around on low load until it is properly hot, but do'nt give it more load than you have to, except when you need to see if it will still miss. I'm dead serious about the untrustworthiness of the calibration of those copy AFMs. Injectors are unlikely to get hot unless the fuel is coming back around hot. You could try squirting them with compressed air or freeze spray to cool them back down to see if they are maybe the cause.
    • Alright, all the plugs looks good. Noticed that it starts to get bad when the car is up to temp, that's when things starts to misfire hard. next to do is Injector cleaning and such. Got in touch with a shop to do work on the injectors next Monday also help on diagnosis.
