Hi all,
I've done a few searches, and I've had a read through this thread about body roll: http://www.skylinesaustralia.com/forums/Bo...ice-t77262.html
Basically, I want to start improving the handling of my R33, reducing some body roll. And I'm on a fairly tight budget (lol, don't they all say that). This car is a street driven daily driver for 99% of the time, so I'm thinking a combination of swaybars and (down the track when I've saved up) upgraded shocks/springs should give me the desired result.
Currently, the car is bog standard in the handling department, other than front and rear strut braces. Power-wise, I'd say it's around the 160-170rwkw mark, with plans to go as high as 200rwkw.
What would you guys suggest?
Edited by bnew
https://www.sau.com.au/forums/topic/204672-my-first-suspension-mod/
If you check out the group buy section with the r33 suspension from Gary - sydney kid - theres some good info and parts there.
I did springs and shocks first
then sway bars and front caster
then f n r camber and rear subframe align kit
If I could do it again - Id go the sway bars first!
I did sway bars. (Whiteline)
Then springs/dampers/caster/camber. (Whiteline/Bilstein)
Then more camber. (Home made stuff)
Then more springs. (Eibach/Bilstein)
Then more sway bars.(Cusco)
And I haven't finished yet.
Best advice is to think carefully about where you want to end up & listen to some of the good advice you will get on this forums. But in doing so recognise that what some people like may not suit you and what suits some circumstances may not suit yours.
If you can do some research on how everything works & what changes have what effects you will be much better placed to understand peoples advice. I mean I have seen some shops recommend 10 & 8 kg/mm spring rates for the street for an R33.....so you can't take it all on trust.
Thanks guys, appreciate the advice. I want to try and avoid being someone who spends all their time and effort making my car go faster, without making it turn and stop better :banana:
Agreed about research- my initial first thought was due to research on SAU, on other sites and talking to people I know that have experience in this area. Can never be too well informed.
Swaybars are the best 1st suspension mod, you will feel the difference immediately.
I have a set of whitline swaybars and they transformed the handling of the car.
Also put whiteline springs and koni yellow shocks, which gave the car a nice drop and handles extremely well with no body roll at all.
I would suggest checking the condition of your bushes first, particularly front castor bushes. If these are worn or in poor condition I woudl replace those first. Then purchase the swaybars.
Yeah, was thinking of doing something like that too actually. Is there anyone on here that sells complete bushes sets? I had a look in the for sale section but I couldn't really see any.
EDIT: Never mind, Ministry of Bass to the rescue :(
Edited by bnew
  • 4 weeks later...
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
    • You can try shoving a borescope down there to see what's up.
