Hi guys, New to the r33 gtst, just need some things clarified.
Current mods are:
2 stage boost control (Currently on 10psi)
FMIC
3.5inch Exhaust with cannon.
Questions I have are:
1. What is a safe amount of extra boost to run on the stock fuel/ignition/ecu setup?
2. Can someone explain the ecu. Does it self tune to adust?
3. What are the next best performance modifications to consider?
4. Does not have a bov, what is the best sounding, and best for maintaining spool between gear changes?
Cheers guys!
https://www.sau.com.au/forums/topic/204711-r33-questions/
Current mods are:
FMIC
Cheers guys!
Safe amount of boost on the stock turbo - 12psi is pretty much as far as you want to go, and even thats taking a risk. Some people get lucky and it lasts ages, and sometimes it dies in no time...luck of the draw.
The ECU might not like going past 10psi, and it might go into boost cut etc....again, some do some dont.
Next mod for you would be some form of engine management...either standalone ECU such as the pfc if you can find 1 (they're discontinued for the 33 gts-t) or 1 of the alternatives. You could also go piggyback with an SAFC2 etc.
As for the BOV, the factory plumb back works fine. If you want a 'cool' sound you'll have to speak to people with different brands/types to find the 1 you want, but it may cause problems with stalling etc.
https://www.sau.com.au/forums/topic/204711-r33-questions/#findComment-3626399
Cheers Dez!!!
How far can the factory turbo go? And what are the compressor sizes on them?
What is the suggested replacement turbo? Plus, is a manifold upgrade worth it? To maybe a tuned length?
Of course this would be after some ecu/fuel upgrades.
All in time I suppose!
I have modified my turbo falcon with a wolf3d,inj, gt35/40 but was dissapointed with the decreased driveability it caused. Did reach 280rwkw though. Hope to match it with the 33.
https://www.sau.com.au/forums/topic/204711-r33-questions/#findComment-3626461
Welcome to the forums.
Let me point you to a quick few links
1. The "bible" of SAU Forced Induction
http://www.skylinesaustralia.com/forums/Fo...ick-t66556.html
It contains many links like below
"First mods"
http://www.skylinesaustralia.com/forums/fi...-co-t45218.html
Also the "Dyno thread" is a great read
http://www.skylinesaustralia.com/forums/Rb...yno-t55845.html
Have a look at peoples mods, what power/response it attained and workout what suits you and what you want.
280rwkw isn't a cheap adventure, so you should do a lot more reading up on things before undertaking any serious modifications.
Lots of info on these forums about all power levels from stock to 500rwkw
https://www.sau.com.au/forums/topic/204711-r33-questions/#findComment-3626582
Cheers Dez!!!
I'll answer what I can...
The turbo, like I said 12psi is the suggested max, and it probably won't make any more power past 12psi anyway, just increase the risk of it failing....it could last 2 years on 12psi, it could last 2 minutes. Not sure on compressor size sorry.
Suggested replacement, thats kind of a broad question...there's a big selection of size/brand etc so it'll be up to what kind of power/response you're chasing.
I personally run a HKS GT-RS on my 33. Forged bottom end etc, standard manifold, the GT-RS is a direct bolt on. It'll max out at about 270-280rwkw with supporting mods, and is 1 of the more responsive turbo upgrades for the RB25DET.
https://www.sau.com.au/forums/topic/204711-r33-questions/#findComment-3626605
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
