Hi guys, New to the r33 gtst, just need some things clarified.
Current mods are:
2 stage boost control (Currently on 10psi)
FMIC
3.5inch Exhaust with cannon.
Questions I have are:
1. What is a safe amount of extra boost to run on the stock fuel/ignition/ecu setup?
2. Can someone explain the ecu. Does it self tune to adust?
3. What are the next best performance modifications to consider?
4. Does not have a bov, what is the best sounding, and best for maintaining spool between gear changes?
Cheers guys!
https://www.sau.com.au/forums/topic/204711-r33-questions/
Current mods are:
FMIC
Cheers guys!
Safe amount of boost on the stock turbo - 12psi is pretty much as far as you want to go, and even thats taking a risk. Some people get lucky and it lasts ages, and sometimes it dies in no time...luck of the draw.
The ECU might not like going past 10psi, and it might go into boost cut etc....again, some do some dont.
Next mod for you would be some form of engine management...either standalone ECU such as the pfc if you can find 1 (they're discontinued for the 33 gts-t) or 1 of the alternatives. You could also go piggyback with an SAFC2 etc.
As for the BOV, the factory plumb back works fine. If you want a 'cool' sound you'll have to speak to people with different brands/types to find the 1 you want, but it may cause problems with stalling etc.
https://www.sau.com.au/forums/topic/204711-r33-questions/#findComment-3626399
Cheers Dez!!!
How far can the factory turbo go? And what are the compressor sizes on them?
What is the suggested replacement turbo? Plus, is a manifold upgrade worth it? To maybe a tuned length?
Of course this would be after some ecu/fuel upgrades.
All in time I suppose!
I have modified my turbo falcon with a wolf3d,inj, gt35/40 but was dissapointed with the decreased driveability it caused. Did reach 280rwkw though. Hope to match it with the 33.
https://www.sau.com.au/forums/topic/204711-r33-questions/#findComment-3626461
Welcome to the forums.
Let me point you to a quick few links
1. The "bible" of SAU Forced Induction
http://www.skylinesaustralia.com/forums/Fo...ick-t66556.html
It contains many links like below
"First mods"
http://www.skylinesaustralia.com/forums/fi...-co-t45218.html
Also the "Dyno thread" is a great read
http://www.skylinesaustralia.com/forums/Rb...yno-t55845.html
Have a look at peoples mods, what power/response it attained and workout what suits you and what you want.
280rwkw isn't a cheap adventure, so you should do a lot more reading up on things before undertaking any serious modifications.
Lots of info on these forums about all power levels from stock to 500rwkw
https://www.sau.com.au/forums/topic/204711-r33-questions/#findComment-3626582
Cheers Dez!!!
I'll answer what I can...
The turbo, like I said 12psi is the suggested max, and it probably won't make any more power past 12psi anyway, just increase the risk of it failing....it could last 2 years on 12psi, it could last 2 minutes. Not sure on compressor size sorry.
Suggested replacement, thats kind of a broad question...there's a big selection of size/brand etc so it'll be up to what kind of power/response you're chasing.
I personally run a HKS GT-RS on my 33. Forged bottom end etc, standard manifold, the GT-RS is a direct bolt on. It'll max out at about 270-280rwkw with supporting mods, and is 1 of the more responsive turbo upgrades for the RB25DET.
https://www.sau.com.au/forums/topic/204711-r33-questions/#findComment-3626605
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
