hey all
the other night i got defected pretty hard, ended up witha yellow sticker, but i need to get a few bits and pieces engineered in order to pass. plus i gotta get dragged over the pits as well.
if you know anyone thats reasonably priced around the north shore/beaches it would be much appreciated.
https://www.sau.com.au/forums/topic/204763-engineer-certificates/
was going to get my car engineered with him, but decided to do more mods first, so can't give you an exact price
Morry Akbarian T: 02 9482 4572
F: 02 9482 4571
Email: [email protected]
Web: www.mobilityengineering.com.au
F: 02 9482 4571
I've used this guy to fit (and engineer cert.) an aftermarket seat to a previous car.
Found him professional and reliable.
From memory the cert. was not cheap.
F: 02 9482 4571
Hey Mikey :O
These guys are next to my work... let me know if you head there. He is strictly by the book though from my experience... although you wont have any issues with the RTA etc..
  • 3 months later...
hey guys
just wondering what engineers cert actually does...does it make u like..."invincible" from cops for items which would normally be defectable...if you have an engineering cert for it?
If it's normally defectable then you wont be able to get it an engineer to certify it. Engineers abide by the book and are supposed to certify that modifications are compliant with ADR's. If they dont comply they wont certify it!
And no, it wont make you invincible from cops.. they will probably still try to defect you for something if you're being a prick to them!
oh ok
so its hardly worth getting then right?
It's worth getting in that; it shows the cops that you've gone to the effort of making your car legit, which sometimes helps... also gives less chance of fines, etc, etc.
If you get a certificate, i believe it also gets blue slipped? (when you get defected it does anyways), so it HAS to be legit... and yeah... if a cop picks on you after that, it's usually only a maintenance issue rather than something to do with ADR.
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
