Apologies for the noob question, but what uses the reddish/orange colour fluid on RB's?
I've found that this colour fluid keeps leaking from under the car. It's from that reservoir on the right side of the motor near the turbo.
Opinions?
https://www.sau.com.au/forums/topic/204783-what-fluid-is-this/
Opinions?
It is power steering fluid. Check the level in the reservoir as it is common for people to overfill them & thereby get a leak when it heats up. If it is not an overflowing reservoir it is usually the larger of the rubber hoses.
Thanks for the responses.
I actually noticed wet piping through the system and found many of the power steering clamps were loose (could twist with gentle touch) so i tightened them and the leak slowed, but wasn't gone.
I also think some of the fluid has leaked on my AC compressor and made it seize.
The PS reservoir is 50% empty now! So i'm going to do a final run down for leaks and fill it again.
Is the best way to fill with the car on, and twist the wheel a few times to help it circulate? Anyone recommend brands?
Edited by R338OY
Mine used to leak PS fluid around the PS cooler, near the stock battery location. I spent 12 months just filling the reservoir up every now and then, but damm did i pay for it.
When i removed HICAS and what not, i spent a good 4 hours degreasing all the filth and crud from under the car... all the way back to the gearbox lol.
Many of my hoses were loose as well.
I recommend spending some time and tracking the leak down ;)
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
