Anyone know of where to get a premade electronic thermo fan kit?? need it for R33 GTST RB25, im sick of replacing stupid clutch fans coz they crap themselves!!!
Hi mate,
I did the conversion on my r34, ive replaced my clutch fan with twin 12inch thermos, theres no kit on the market for the skylines your going to have to mix and match, i used AU twin thermos in mine then you have to cut the shroud to fit because i wanted twin 12inch thermos is a extremely tight fit and alot of messing around. Then you have to wire up a thermo switch which is also a bit of mucking around. I'm not going to say to do it unless you have a lot of time, and have a decent a mount of mechanical skills or have a lot of money to let a mechanic to do it cause there is A LOT of labor involved. But my system never sees half way even on a hot day with the a/c on full. Hope this helps a little.
:banana: Good luck.
What do you mean by "they crap themselves"? You would need to be very unfortunate to keep replacing a crap fan with an equally crap fan. What makes you say all your fans had crapped themselves?
haha R33 clutch fans are god. Use them on all the crazy SR's we build.
if you must go the thermo route like i did for room issues on the 26 conversion use Flex-A-lite part number 220
perfect bolt on size for skyline radiator.
Hay can someone explain how the clutch fan is attached to the engine and what makes it spin, and also how it would stop working.
Does the clutch just seeze up or just ends up spinning freely ..
Edited by Mick
either they sieze up or start spinning with the revs of the car, or the blades snap off (had that happen once). Plus the stupid intercooler kit i got made me cut the inside edge off each blade so it didnt hit (that was the one that snapped) ive relocated the piping and spaced it so nothing hits anymore (or even comes close).
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
