Hey people, bought an manifold off ebay (yes i know cheap copies crack etc etc) however this one looks really quite good! It reminds me how a guy that i knew a few years ago used to build them himself.
The welds look good.. its a tuned lowmount manifold (guy states was pretty much designed for HKS turbos and also has a split dump he can supply for different flange with the GT3037.
$400 + $35 postage
$116 for manifold gasket from nissan.
seems ilke a cheap option he states 15-25KW Gain from this manifold.. (i can see how as factory manifold is not a tuned length and this one looks well ported and i cant see any difference between this one and a DRIFT one or equiv that sells at autobarn for $1000. (i also know custom ones sell for this price as well) but really? what do you guys think? even the bolts look easily accessable which is normally a problem. ive posted some pics!! Guy sells them from South Australia.. so fellow aussie. He did say he has to order them so i assume hes not manafacturing them.
post-46561-1202290372_thumb.jpg post-46561-1202290386_thumb.jpg post-46561-1202290397_thumb.jpg post-46561-1202290411_thumb.jpg post-46561-1202290558_thumb.jpg
Sellers item description:
Low mount stainless steel turbo manifold suits all Nissan Skylines R32, R33 & R34 with RB20DET & RB25DET Engines.
Tune Length Runners, with Excellent Custom Collector Design!
Bolts in stock position with no mods!
All mandrel bent tubing comprising of stainless steel all TIG Welded, very strong and will never rust.
Comes with highly polished finish.
Ported and Hi-flowed, and will increase turbo spool and we have seen power increase by 15-25rwkw depending on turbo/engine combination.
Increase performance, torque and looks all in one go!
Edited by SLYDA
https://www.sau.com.au/forums/topic/204846-400-low-mount-manifold/
this guy is also on the sau forum im not sure what user id, i asked a few questions and all i got from him where one word answers ,that was from ebay .i did not contact him on the forum cos maybe he did not wont people to know he was a business selling in the private sale area. tell us how you go and show a dyno be for and after if you can
they definately look good when they havent been installed, but its the actual quality of the s/s that lets them down. I havent had one that has lasted anymore than 12months, and allthough after the first week of it being installed it looks great with its golden glow, that tends to change shortly after to a dull brown. With the extra power you will being making with that turbo (and heat) i would be suprised if it lasted 12months.
Not saying its a bad thing, some people cant justify spending over a grand on a manifold, but when you replacing them annually it starts to get annoying imo. Hope this one lasts abit longer for you and good luck with the dyno :D
i just paid closer to 2k.... trust me (after 10 years in the trade) you get what you pay for and i was happy to fork it out..
The design on the one youve posted is actually very good (i posted the whole story in another thread) but as for material it is hard to tell without seeing it personally.
hmm.. ill have a look at the flanges when i get it - may be worthwhile doing,
asked the guy a few questions and he replied:
"Hi Champ, ill be sending your manifold off tomorrow, also included will be gaskets for the manifold to head and manifold to turbo as well as nuts and bolts to secure turbo to manifold,you might be able to reuse you orginial gasket as long as it doesnt break. Change all the studs to secure the manifold to your head with new ones they tend to brake, you can use rb30 vl ones they are the same on all the rb's, on two of the runners due to the tight bends you will need to use 10mm length studs ( So shorter ones)."
I actually changed the studs 2 years ago and got 3 drilled but i got them all out and will replace them again anyway.
This one has a better collector setup than most ebay jobs.
the collector setup was the only reason i bought it, looked really well designed and it was a tuned length, looked like it had been TIG welded quite well. the cheap ebay ones look slapped together, welds are shocking, its also a low mount not a high mount like the one in the displayed pic.
This is a cheap $200 ebay top mount manifold that is claimed to be Stainless SU304..
Edited by SLYDA
I was tempted to go for the same manifold as you SLYDA but opted to go high mount with the GT35R.
i would have gone top mount as well however i bought it as a HKS 3037 Pro S kit, so it already had the suction pipe made up, all the lines etc etc, didnt want to complicate things, or i guess draw it to the cops attention there was a huge big turbo sitting up there haha.. and GT35R was just a BITTT out of my price range! ill consider selling the 3037 after i have a built motor.
Edited by SLYDA
My turbo has no internal gate, it looked like it was going to be a pain in the ass to get a gate pipe onto the lowmount manifold and it also looked like the turbo would hit the strut tower. I would have preferred to keep the turbo low but for ease, it's going to be high mount ;)
Good luck! interested to see how it pans out :P
    • Ha ha, yeah, I've had one following me around in my parts boxes since about 2007 I believe. Just a little iddy bit hole drilled in the one I have to let it vent out once pressure was removed from the engine side. Still no idea what I'd put it on, ha ha.
    • Just read this... Just a little bit of a wild one! Do you think the driver was testing out a new feature/device for how to lose the cops in a high speed chase?   I also suspect, if the box has a road sweeper that does magnetic metal pick up, he does a LOT of work in the machining industry. Which is what most of that looked like, machining chips from a mill or lathe. And I bet they're RAZOR sharp! And from an environmental perspective they really do need to actually collect all of those little pieces too. I wonder how many people still cop flat tires over the coming months on that road?   As for insurance company, yeah, it'd be interesting to hear what they say to the owner. But realistically, he's right, that "It's his fault". In the way that, it was his truck that spilled it, so they need to clean it up. However, neither he, nor his insurance company may bear the end cost if they do an investigation and find out it was caused by someone elses negligence (And they know who)...
    • Yeah, no matter what bad things people can say about Julian from Autospeed, he at least was capable of thinking and his inclusion of a check/relief valve in the plumbing for the Audi boost controller, that I made a copy of and used for years**, completely eradicated that problem. **It's still lying on my workbench where I put it about, um, 18 years ago and have never found a home for it!
    • I didn't actually know this! I've seen photos of the H1, mainly outside shots, and they just look "different". I guess there'd be a few little changes like nicer rims, and probably the fact they have nicer looking paint with some depth and shine, which will make any vehicles body look different to the very flat colours of the defence force.   I've watched the guys on GHPC convert their Humvee to LS1, and they've done some really nice front shock upgrade. I'm waiting for the next video on it with the rear end done. I can't remember if they've already done it, or I dreamed it, but I believe they're also supercharging theres. They will be in the future doing proper long travel suspension too.   If you ditch out your big V8, as rubbish as it must be, send it to my place. I'll let the unreliable V8 motor and box be here. I just like V8s... So I'll find something to do with it... Even if that something is just taking up valuable space in the yard. I might have something Skyline I can send back in payment... Or even Ford Barra motors  (From memory you're in Canada yeah?) So you can then play with the legendary Aussie 4L version of an RB...  Except they don't have that distinctive random miss at idle like the RB25 does.
    • Or you mean the age old problem of early 2000's manual boost tees, where they never let the pressure out of the line between the boost tee, and the waste gate, so after your first trip on boost, the damn wastegate liked to stay open and be laggy on gear change?
