egghhh do NOT put one of these manifolds on before putting on ur rocker covers u CANNOT get the right side one on once it is done up. It also is a HUGE pain in the god dam ass to get the turbo in there as well.. like a GT3037 Pro S. You also need 2 shorted studs that are like 10mm less coz the bolts at the standard length hit the runners. You can find the guy on ebay by searching for RB25 manifold (its there as like an SS Tuned length) bla bla bla.. comes with manifold, gaskets, Bolts for turbo to flange however there useless as the head on them is to big and there to long and cant get em to bolt to a HKS turbo, had to go get 4 studs, 8 nuts (even though the is a dye cut thread in flange (just dont trust it)) so i can bolt the stud to flange and turbo to flange. It also comes with manifold to turbo flange.
    • It's (the TPS) buzzing? Or something else is buzzing in response? Remove the IACV from the plenum. Block the hole into the plenum with your hand. Get someone to start the car. Let some air is. Do the revs flare up? This is checking that the path into the plenum is clean. After that, is the air hose leading to the IACV fuly clear? After that, either you didn't clean it thoroughly enough to allow the valve to move, or it is broken.
    • Just a follow-up on this topic. From what I can tell so far the rusty residue on the engine block might be unrelated to a coolant leak or maybe just older than anticipated. After driving it from the winter garage to my friend's garage I could not see any new traces of coolant leaking there, but I will test this properly once I was able to fully warm up the car and drive it for a bit. I think I can agree that the whole porous engine block stuff is kind of nonsense, but there is just a silly amount of true, false and half-true information on anything Skyline-related on the internet.
    • hrmmm , not mine , easter plans to pull engine not happening
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
