  • Replies 50
I have had better days thats for sure... i changed a lot in my rear suspension AND i changed ,y diff ratio from a 4.3 to a 4.1 and the car is just shit now... so laggy. i managed to adapt to the suspension changes... makes it harder to drive but theres a lot of grip there... now i just need to change the diff back to a 4.3.
was def having an off night... made so many mistakes and miss shifts. i was pretty pissed off with myself but then i remembered drift is suppose to be enjoyable lol. Hayden and i had a couple of close runs but he had a lot of drama with rear grip also... a total lack of it!
lol wow, you looked awesome out there to me simon, think your a little hard on yourself, although i only saw turn 1 and 2 and didnt see you miss a beat there.
Everyone else did well too, matty definately improving. Brenton had some nice slides going on, what size is your gate brenton? cause my god your car screams!
Well done to all out there and ill hopefully join ya's back out there in march.
No ext. gate.
AM Perforance Screamer pipe.
:yes:
I want one too.
And by f**k I want to get out there. Sick of the 31 being in the shed.
Edited by R31 drift pig
I may have some on the other 'pile' i was just being fussy what i uploaded :S
Never shot in low sunlight with this camera so my settings were way off, heaps of photos turned out over/under-exposed or just blurry and plus i was getting sprayed with smoke, dust, rubber lol
Ill have top check through the rest of the photos..
or random people spinning in front of you so they can come and say hi :)
wait wait... brentons car screams?? what bout mine hahaha
yeah AM performance exhaust FTW!!
Havent heard your car simon. Been staying away from drift pracs etc. because it depresses me too much not being out there :laughing-smiley-014:
yes simon, your car screams, but we are used to that :D
brentons has just grown some balls and a voice since last time i heard it lol.
oh by the way simon, i was one of the guys that came upto you before you pulled out of your pit at the end of the night, one of the 2 telling you about the cops, i was in the nissan jacket.
Well there was a cop giving a bit of trouble to some people, was talking to a guy in a green rotor - was on trade plates, the cop stopped him n gave him a bit of grief, threatened him a bit, so he came back in and stayed for a bit longer.
Heard 1 car got defected earlier in the evening just before drifts ended, but thats about all
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
