Make: Nissan
Model: Skyline R33 GTST
Milage: 98,000
Transmission: Manual
Colour: Maroon
Complied? Yes
RWC supplied? No
Currently registered? Yes
Price: $16,000
Contact: Marc on 0403 363 143
Comments / Modifications:
Hey All,
This car is VERY quick and is a real head turner. Below is a list of all the modifications that have been done to the car, making well over 300rwkws (around 340rwkws). If there are any questions please feel free to pm me or give me a call on my mobile.
1995 dec built r33 gtst, 98000kms,
ECU/Engine/Exhaust
350rwkws
APEXi power FC with H/C
Garrett T04Z 800HP twin ball bearing turbo.
Turbo smart 45mm waste gate with dump to atmosphere.
6 boost high flow exhaust manafold
Trust type-R BOV
Tomei 264 in/ex camshafts
Tomei 280L/H Fuel pump
NISMO 550cc injectors (This is what he was told when he purchased the car, but when the car was dyno'd the tunner said they were more likely 660cc)
NISMO Fuel regulator
NISMO Oil cap
Fujitsubo 3.1/2in exhaust with high flow cat
3 1/2in custom dump
Greddy Exhaust Adjustable Cam Gear.
Greddy Engine Oil Cooler
Greddy Oil Catch Can
Greddy Intake Plenum
Greddy Profec B boost controller
Port and polished RB25DET head
Q45 Throttle Boddy 90mm
Q45 AFM 90mm
Suction and cooling
APEXI power Intake
TRUST V-SPL Intercooler kit
Drivetrain
C's Quickshift kit
OS Giken Twin Plate Cllutch with lighten Flywheel
NISMO Oversixe slave clutch cylinder
Handling
Tomi Brake Master Cylinder Brace
FET Strut Tower Brace(f)
CUSCO Strut Tower Braces ®
DBA Drill and Slotted Roters (F&R)
Bilstein Strut and Whinelint Spring
Section HICAPS Lock Bar
Whiteline Handling Pack
Whiteline Urethene suspension bushes (F&R)
Whiteline anti-roll bars (F&R)
Interior
APEXI EL Mechanical Boost Gauge
APEXI RSV with DIY shift light
MOMO Steering Wheel
MOMO Gear Knob
Pioneer MP3 Head Unit with Pioneer Speakers/Spliters (F&R)
Exterior
R33 GT-R Front Bar with indicators
R33 GT-R style Rear Wing
R33 GT-R Style side skirt
3 Point immobiliser Alarm
The car will be sold with the STD R33 rims, not the 19's in the pics.
Images:
Additional photos can be found here: http://s238.photobucket.com/albums/ff292/t.../Skyline%20R33/
Will try and find the dyno sheet to scan in this week.
Whoever buys this car will not be disapointed!!!
Marc,
https://www.sau.com.au/forums/topic/204864-r33-gtst-300kw-monster/
How much boost is it running?
Also you interested in swaps at all?
And is it your car cause in your other post it says it was someone else's...
http://www.skylinesaustralia.com/forums/19...60#entry3395960
N1GTR: yes it is still a stock bottom end.
weeman: yeh I dont think many people actually know what 300+kws feels like, especially when you can put your foot down at 80kmh and the thing starts sliding up the road!!
nice_r33: It is making that power on 21psi, yes it is a mates car he came back from America so decided to drive it aroudn while he was back but has now moved over to Perth so the car has got to go. No trades sorry as he needs the cash..
Guys this is a SUPER cheap car when it is concidered how much money has gone into this car, alot of brand name bits and the car has been driven VERY little over the past few years as he has not been around much.. It has been very reliable and there is nothing to be spent on this car (i.e no problems)
Marc,
Edited by ThEdArKrAvEr
thanks for ya reply,
would have been interested if he was after a swap,
good luck with the sale
Thus why the boost has only been wound up to 21psi, there is plenty of other skylines out there making this power on std internals without any problems.
The supporting setup would be good for over 400rwkws (T04z etc) with forged pistons and a set of rods or an RB30 bottom end but so that the motor will last (and with the thumbs up from 3 different tunning shops) the boost has been kept down and still making great power.
Plus obviously this has been taking into consideation in the price as with built internals you would be looking at 20k for a car with similar modifications.
Marc,
worst case bottem end goes on it, chuck rb30 bottom end, or build up a rb25 for bout 1500-2k.. under 20k for over 350rwkw... i'd be happy with that.. costs alot more to build something as such.
Spot on dead32, you’re looking at 10-13k for a std R33 throw a T04z turbo on that’s $2100, 6boost exhaust manifold $1200, Power FC $1000, Injectors $600-800, Greedy intake manifold (genuine) $1000, cams $700, 3 1/2 inch exhaust $800, Turbosmart wastegate $700, Twin plate clutch $2200 and you have well over 20k there.
Have not even started to mention suspension, brakes, other engine mods, tunning etc etc etc.. It is obvious allot of money has been spent on this car and if the person that purchases car decides they want to chase more power you are only looking at internals and injectors and I will guarantee you would be looking at 400kw+!!!!!!
Marc,
  • 3 weeks later...
    • Jdm DC2R is also nice for a FF car compared to the regular hatches of the time.
    • Gotta admit, I love the 20b Cosmo.
    • Now that the break-in period for both clutch and transmission is nearly over I'd like to give some tips before I forget about everything that happened, also for anyone searching up how to do this job in the future: You will need at least 6 ton jack stands at full extension. I would go as far as to say maybe consider 12 ton jack stands because the height of the transmission + the Harbor Freight hydraulic platform-style transmission jack was enough that it was an absolute PITA getting the transmission out from under the car and back in. The top edge of the bellhousing wants to contact the subframe and oil pan and if you're doing this on the floor forget about trying to lift this transmission off the ground and onto a transmission jack from under the car. Also do not try to use a scissor jack transmission lift. You have to rotate the damn thing in-place on the transmission jack which is hard enough with an adjustable platform and a transmission cradle that will mostly keep the transmission from rolling off the jack but on a scissor lift with a tiny non-adjustable platform? Forget it. Use penetrating oil on the driveshaft bolts. I highly recommend getting a thin 6 point combination (box end + open end) wrench for both the rear driveshaft and front driveshaft and a wrench extension. These bolts are on tight with very little space to work with and those two things together made a massive difference. Even a high torque impact wrench is just the wrong tool for the job here and didn't do what I needed it to do. If your starter bolts aren't seized in place for whatever reason you can in fact snake in a 3/8 inch ratchet + 6 point standard chrome socket up in there and "just" remove the bolts for the starter. Or at least I could. It is entirely by feel, you can barely fit it in, you can barely turn the stupid ratchet, but it is possible. Pull the front pipe/downpipe before you attempt to remove the transmission. In theory you don't have to, in practice just do it.  When pulling the transmission on the way out you don't have to undo all the bolts holding the rear driveshaft to the chassis like the center support bearing and the rear tunnel reinforcement bar but putting the transmission back in I highly recommend doing this because it will let you raise the transmission without constantly dealing with the driveshaft interfering in one way or another. I undid the bottom of the engine mount but I honestly don't know that it helped anything. If you do this make sure you put a towel on the back of the valve cover to keep the engine from smashing all the pipes on the firewall. Once the transmission has been pulled back far enough to clear the dowels you need to twist it in place clockwise if you're sitting behind the transmission. This will rotate the starter down towards the ground. The starter bump seems like it might clear if you twist the transmission the other way but it definitely won't. I have scraped the shit out of my transmission tunnel trying so learn from my mistake. You will need a center punch and an appropriate size drill bit and screw to pull the rear main seal. Then use vice grips and preferably a slide hammer attachment for those vice grips to yank the seal out. Do not let the drill or screw contact any part of the crank and clean the engine carefully after removing the seal to avoid getting metal fragments into the engine. I used a Slide Hammer and Bearing Puller Set, 5 Piece from Harbor Freight to pull the old pilot bearing. The "wet paper towel" trick sucked and just got dirty clutch water everywhere. Buy the tool or borrow it from a friend and save yourself the pain. It comes right out. Mine was very worn compared to the new one and it was starting to show cracks. Soak it in engine oil for a day in case yours has lost all of the oil to the plastic bag it comes in. You may be tempted to get the Nismo aftermarket pilot bearing but local mechanics have told me that they fail prematurely and if they do fail they do far more damage than a failed OEM pilot bushing. I mentioned this before but the Super Coppermix Twin clutch friction disks are in fact directional. The subtle coning of the fingers in both cases should be facing towards the center of the hub. So the coning on the rearmost disk closest to the pressure plate should go towards the engine, and the one closest to the flywheel should be flipped the other way. Otherwise when you torque down the pressure plate it will be warped and if you attempt to drive it like this it will make a very nasty grinding noise. Also, there is in fact an orientation to the washers for the pressure plate if you don't want to damage the anodizing. Rounded side of the washer faces the pressure plate. The flat side faces the bolt head. Pulling the transmission from the transfer case you need to be extremely careful with the shift cover plate. This part is discontinued. Try your best to avoid damaging the mating surfaces or breaking the pry points. I used a dead blow rubber hammer after removing the bolts to smack it sideways to slide it off the RTV the previous mechanic applied. I recommend using gasket dressing on the OEM paper gasket to try and keep the ATF from leaking out of that surface which seems to be a perpetual problem. Undoing the shifter rod end is an absolute PITA. Get a set of roll pin punches. Those are mandatory for this. Also I strongly, strongly recommend getting a palm nailer that will fit your roll pin punch. Also, put a clean (emphasis on clean) towel wrapped around the back end of the roll pin to keep it from shooting into the transfer case so you can spend a good hour or two with a magnet on a stick getting it out. Do not damage the shifter rod end either because those are discontinued as well. Do not use aftermarket flywheel bolts. Or if you do, make sure they are exactly the same dimensions as OEM before you go to install them. I have seen people mention that they got the wrong bolts and it meant having to do the job again. High torque impact wrench makes removal easy. I used some combination of a pry bar and flathead screwdriver to keep the flywheel from turning but consider just buying a proper flywheel lock instead. Just buy the OS Giken clutch alignment tool from RHDJapan. I hated the plastic alignment tool and you will never be confident this thing will work as intended. Don't forget to install the Nismo provided clutch fork boot. Otherwise it will make unearthly noises when you press the clutch pedal as it says on the little installation sheet in Japanese. Also, on both initial disassembly and assembly you must follow torque sequence for the pressure plate bolts. For some reason the Nismo directions tell you to put in the smaller 3 bolts last. I would not do this. Fully insert and thread those bolts to the end first, then tighten the other larger pressure plate bolts according to torque sequence. Then at the end you can also torque these 3 smaller bolts. Doing it the other way can cause these bolts to bind and the whole thing won't fit as it should. Hope this helps someone out there.
    • Every one has seemed to of have missed . . . . . . . The Mazda Cosmo . . . . . . what a MACHINE ! !
