Hey guys,
Just curious in regards to the p-plate laws that state that no p-plater may drive a car that has had any modification to the engine that requires an engineer's approval.
I wanted to change the cam gears, camshafts, pistons, valves and crankshaft...as well as lighten the flywheel...not allowed? or allowed?
Cheers guys,
Cartz
you could pretty much garrantee doing that stuff would be illegal, part of the p plate law is law against engine modification.
That said, they would NEVER know, all that internal stuff they could never find out, you've just gotta make sure you keep the engine standard looking, i'd be keeping the airbox with a highflow panel filter, stock exhaust manifold, high flow cat, stock turbo exhaust? just make sure its quiet. you dont want the car to sound lumpy, but if you sort the vct properly (r33?) it should idle pretty smooth, 60mm nissan tb, hide the ecu, dont have any rice inside the car or engine bay, or outside the car.
that intake and exhaust would really lose sfa performance, and considering that means the cops wont even look twice, its you best option. What counts is whats in the engine :O. Decent cams, good compression, balence, tune, the right headwork and it will be a weapon. what do you mean crank shaft?
Question - Allowed or not ..
NOT ALLOWED TO DO ANYTHING UNLESS YOU OWNED IT PRIOR TO LAW INCEPTION, OR YOU HAD YOUR LICENCE BEFORE LAWS.
Question - Will they know?
No chance unless you sound like you've got a 9 second engine running .. You know cams etc..
Yeah, i was also thinking of doing an exhaust and what not...but the main part of the law stated that it was only NOT allowed if it required an engineer's approval post-modification...
Do cops usually take off the timing belt cover? If so, it probably wouldn't be a smart thing to change the cam gears..
I was gonna put in a forged and lightened crankshaft...
No Aftermarket ECUs are allowed?
Wouldn't it be good if there was a thread that simply stated WHAT legal modification are allowed on the new p-plate laws?
Basically, i'm going to see how much power i can get out of an rb25de...but i want to do it legally, and not cut corners...(nothing beats the sound of a properly tuned and modified NA engine)...
Cartz
ECU they can check.. Timing belt cover they wont take off.. To much effort/risk involved.
If you get HWP your going to be nailed .. But its just a $200 fine and 3 points I think.. 1 Yr isnt much to wait .. Just save up a shitload of cash for a RB26 conversion :no:
Well if that's the case, why not just save up for a turbo?
It's also 2 years where i am...
3 year total if you've just gotten your licence...
HWP?
They never would, and probably wouldnt know where it was
the cam cover would NEVER come off the engine.
The whole point is, you drive around in a stock lokoing car, stock interior and stock engine bay, they'l send you on your way within 30 seconds. just be polite and say you just drive it for the badge, but you know its a jap taxi and its good on fuel being only a 2.5L etc...
you have nothing to worry about, as long as its quiet, which i personally prefer anyway (for a daily), because you can get infront of people without everyone looking at you like your a hoon criminal.
edit: the only thing you'd have to worry about is emmissions, which i highly doubt would be tested on a 'stock' exhaust, and with a decent tune on some good fuel (gogo E10) with o2 working and cat, aslong as the cams aren't outrageous, you should still pass ok. BUT once again a stock car, you wont have any problem.
Edited by SKiT_R31
exactly! my car has minimal asthetic mods and looks stock. never in my 4.5 years of owning it have i been pulled over because it was a skyline. RBT yes of course.
don't drive like an idiot, don't attract attention to yourself and you're on a winning formula.
i havent even had my skyline for 3months and ive been pulled over 6times by the popos. mine is completly stock and they have gotten under the hood and made me rev my stock exahust. im pretty sure exahust, filter and extractors are all legal, not sure about the rest, but what cant be seen cant be tested. they wont pull ur motor to find out if anything is suss.
keep it nice n quit n clean and u will be fine. or save ur money n buy a turbo when ur off ur p's n start modding it then.
I don't want a turbo...hence this being in this thread...lol
I feel important to mention hes a P plater, its like driving a car with DEFECT as the number plate..
But I suppose they do it for a reason, prevention of speeding because you always get pulled over...
Any yeah they do look for the ECU, they had a nice run of it in sydney a yr ago.. Its not common tho.
Is there any way to hide the ECU? say...under the center console?
Wack a nissan sticker on anything that says a name, that should do it.. its only seriously done cars they will check(but I guess it depends if they wanna nail you), and thats if they dont have a engineers
Edited by DECIM8
as i said previously, check with your local state's rules and regulations into what you can or cant do.
trying to hide mods is all good and all, but in the end you will void your insurance. also keep in mind alot of cars come from factory and don't even meet ADR requirements.
you have answered your own question in the first post.
  • 2 months later...
  • 1 month later...
Personally, I'd wait till you are off your Ps before doing any "major" engine mods. Best to avoid the hassle from the boys in blue. The only change I'd do is put a K&N panel filter - but i'm not sure about the "legality" of this.
For now I'd recommend some sort of suspension/braking upgrade to start off.
    • I found the same with Subaru’s.  I own and love the SG9 Forester, after that model 2008+, Subaru threw the ugly stick at all their line up and somehow managed to make them look worse with every succeeding year.  lol
    • It's something we all have to consider as time marches on. Also consider lifted rally MX5 conversion at that point.
    • I should be fine for a few more years, whilst I do have arthritis I also exercise and do mobility training every day to keep as fit and healthy as I can, military life, which is the actual cause of most of my joint issues, has set daily regimes, which I weirdly enjoy I also train alot smarter now, not really focusing on lots strength or puffy muscles, I'm more focused on maintaining what I have for my future older self, I actually train as much mobility now as I do exercising Check out this "simple" drill I have been doing daily prior to training now for a while now, this has worked wonders in my all round mobility
    • I'd say one thing that may make you sell is the same reason the guy with the hard top roof sold his. He got old, and his back was giving him too much grief stopping him getting in and out... Old guy said he was 73! He looked and sounded younger than 73 to me! Or maybe I'm just aligning with old people more...
    • Already looked at a few prior to getting the MX5, really nice car, had all the mod cons, but I wasn't really sold on the new "look" I did miss my 2017 Limited, and I personally prefer the "look" of the older car over the new model, but, when pondering I kept going back looking at MX5's But it was same same for the new ND's, I wasn't sold on the new "look", especially the RF with its weird roof, which only half goes down, like a targa top sort of thing As I stated before, I did look at NC's, but the cars I looked at were PRHT's, but I didn't like their roof line "look" of the PRHT, until I saw the soft top version, (someone on SAU posted a for sale ad for one with a soft top that caught my attention, you can blame them for my choice.....🤣) and.... that old style detachable hard tops were available for them, which keeps the old MX5 more smoother flowing roof line, and the more rounded body style, similar to the NA-NB, to me, the arse end of the ND looks to "modern" Much like how I prefer the NC1 front bar, over the later models How long will I keep this car for is unknown, but currently, there's nothing else out there that "floats my boat" for a small, fun, little "sports car", that I can play with and enjoy looking at and driving But, who knows what the future holds, and going off current new car styling, if I replace it, it will be a older model something something
