I've been driving on my P's in NSW for the 2.5 years now. Every car I've had (including a turbo one for a very brief period of time) has had engine modifications. I've had a Onevia, a Silvia, and my current car is a E30 BMW.
I've never even had the bonnet popped, and believe me, the Onevia was incredibly ghetto for a period of time.
Just do it.
Just do it.
lolol i thought it was you pete..
ive only been pulled over once at a RBT in the skyline..
my sil i was pulled over a few times and defected once.. it had wide guards, driftteks, it was lowered and loud..
from one nonturbo p plater to another i say...do the mods. ive had my sil (a very loud one at that) and have been pulled over about 5 times so far and the only thing they checked was tyres- never opend my bonnet. but all i have is a full exhaust and blitz pod filter which is not enclosed. if i had the money i would go for it. relocate the new ecu and keep the stock one there with the wiring leading to nowhere. the only main issue i would be worried about is cams.
g'luck
What difference does the fact that it's imported make?
cops target imports more then other modded cars.. unless theyre rediciously over done.. 20" chromies, flash paint job, decked, full hectic sound system etc in something like a lance
Edited by dori32
i dont know about any other state but i know in NSW anything that requires and engineers certificate is illegal for P platers, which is kinda stupid as any modification to a car needs to be engineered, even putting in an alarm, cops dont seem 2 anal about it which is good
anyways with my lumpy cam i just drive like the car is having issues when a cop is behind me a min or so later they usually piss off
in short do suttle or hiden things and always play dumb like u know nuthing about cars and its how it was when u bought it
This is where the line gets blurred. The government bans all performance modifications.
Now what does this mean?.. buggered if anyone knows. Lightened wheels can help performance.. but so do bigger brakes..
Bear in mind.. your averge joe cop is not know the diffrence between his you know what hole and his ear hole when it comes to "performance parts" and what that entales..
honestley.. mod away and hope for the best..
  • 1 year later...
Ey man i got Red P's have a n/a r34 gt, and have been randomly pulled over bout 8 times in 6 months. i was pulled over this morning on the way to work and was asked to open the hood.
i thought f**k lol. I have a chrome-painted pod filter that is mounted low but not wat i'd call hidden,
everything else is stock, no exhaust or bodywork even. i have both p plate clearly visible, good tyres and just an overall clean/quiet car. and the cop looked at the engine for about 10secs and let me go.
i seriously dont think many of them know (or are taught) wat to look for, as the focus is on alcho and actuall bad drving. If u don't hoon around alot and u have a clean and quiet car with no damage or silly things like decals and a million look at me, self-altered interior mods, and u treat the cops with respect and such... they probaly figure its a safe car and will let u go. they have better things to do. just dont be silly bout it.
heathy,
Actually in NSW its engine performance modifications that require an engineer cert that are illegal, things like engine swaps etc they don't really care about exhausts(as long as they are under 90db) or any other minor mods.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
