●HIGH POWER CONTROL UNIT ハイパワー コントロールユニット
R33_p.cntrl.JPG今やクルマの全てのパフォーマンスを握るのはコンピュータといえる。その頭脳は何よりも頑丈で、正確でなくてはならない。インパルのハイパワーコントロールユニットは、クルマの本来の潜在性能を十分に引き出し、誤作動とは無縁のスーパーユニット。
■価格:
RB25DET用
186,900円
(税込)
(純正品下取りの場合 )
123,900円(税込
Hi can some one please help me with what this says if you can just pm-me back or post it up here in english.
Cheers
Allan.M
https://www.sau.com.au/forums/topic/204906-need-help-translating-to-english/
- HIGH POWER CONTROL UNIT High POWER Control Unit
Now you can call that all performances of the car are grasped the computer. As for the brain of Now all of the car's computer and grip performance. being stronger than what, as for the て it does not become not to be accurate. The high power control unit of The robust brain more than anything else and the is not accurate. in pal to pull out the original latent efficiency of the car sufficiently, erroneous operation unrelated super unit. INPARU HAIPAWAKONTORORUYUNITTO of the original car's performance potential drawer FULL, and malfunctioning unit is immune from the supermarket.
* Price: * Price: For RB25DET For RB25DET 186,900 Yen 186,900 yen (Including tax) (Tax included) (In case of genuine products trade-in) (Trade-in the case of genuine products) 123,900 Yen 123,900 yen (including tax (Tax included
This computer can control all the existing functions of the car. Its processor is very powerful, and well suited. The Impul High Power Control Unit will bring out the full potential of your car without any problems.
That's what I got out of the blurb in the middle.
im researching abit on the impul auto ecu because i have paid for one and just waiting for it to come now
impul ecu removes the boost cut and speed limiter.
also improves the power slightly.
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
